Any Advice On Cutting Glass Backsplash Better? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree5Likes
  • 1 Post By Nealtw
  • 3 Post By de-nagorg
  • 1 Post By ront02769
Old 02-17-2019, 12:38 PM   #1
Rewards Points: 110
Any advice on cutting glass backsplash better?
The glass cracked. I have a 4" diamond grinder blade and a diamond jigsaw blade. The jigsaw blade was basically useless.
Any advice on cutting glass backsplash better?-0217191235_hdr_1550425110974.jpg
farmerjohn1324 is offline   Reply With Quote
Old 02-17-2019, 12:44 PM   #2
retired framer
Rewards Points: 1,284
Re: Any advice on cutting glass backsplash better?
I would remove all the pieces that need to be cut and put the rest of the sheet in place,
Make some kind of jig to hold the little tile and cut them with the grinder and put them in individually.
Before you remove them from the sheet, mark out the cut lines and mark which end will be waste so you don't get confused when cutting.
landfillwizard likes this.
Do not use flat bottom gables with scissor trusses.
Old 02-17-2019, 01:31 PM   #3
Super Moderator
Gymschu's Avatar
Rewards Points: 132
I've had good luck with the mini glass tile cutters at Lowe's. I didn't think it was possible to get good, clean cuts with the tool, but, I did. Some were a bit rough, but I hid those pieces behind outlet covers, etc.
"In the heat of battle, my father wove a tapestry of obscenity........."
Old 02-17-2019, 02:29 PM   #4
JUSTA MEMBER
Rewards Points: 290
I use a Diamond blade WET-SAW with a sliding platform to rest the tile piece on.
Separate the sheet into 2 parts, then remove the ones that need cut, and cut each one individually.
Then when placing the sheets, install each piece individually, using tile spacers to get them correct.
ED
Wet- Saws are rentable, or purchasable if you will be using it a lot.
There are little ones that are less money, but takes more time and care to get perfection with, and won't be very useful for a larger tile.
ED
daveb1, landfillwizard and Domo like this.
de-nagorg is offline   Reply With Quote
Old 02-17-2019, 02:40 PM   #5
Rewards Points: 110
Do you think it's a waste of time trying to cut the glass tiles horizontally? Is it just asking too much?
The stone ones are no problem.
Old 02-17-2019, 03:46 PM   #6
Super Moderator
Gymschu's Avatar
Rewards Points: 132
It would be next to impossible to cut them horizontally IMO using the type of cutters I used. Vertical cuts weren't bad at all. I was lucky in that I didn't have to make any horizontal cuts.
Old 02-18-2019, 04:31 PM   #7
Rewards Points: 674
If you can cut.the stone tile horizontally then only use stone tile for the horizontal cuts. You may need to change some of.the other stone tile for glass ones to keep a random pattern, but it will give you the stone ones you need for the lengthwise cuts.
daveb1 is online now   Reply With Quote
Old 02-20-2019, 07:43 AM   #8
Rewards Points: 832
I'm with Neal—cut out from the backing the pieces that need to be trimmed. Use a wet saw to make the cuts in those pieces.
huesmann is offline   Reply With Quote
Old 02-20-2019, 07:44 AM   #9
Rewards Points: 832
Old 02-20-2019, 08:23 AM   #10
Rewards Points: 2,568
we use 4" grinder & diamond blades for small cuts - wet saw w/diamond blades for larger work,,, just slice slowly
Old 02-21-2019, 12:16 AM   #11
Rewards Points: 110
How do I break the dried grout to remove this outlet cover? I need to get it off to put the extension behind it. Photo is blurry, but it's grouted in.
Old 02-21-2019, 02:47 AM   #12
retired framer
Something like this, or a similar blade in a multi saw.
https://www.bunnings.com.au/qep-carb...t-saw_p6821648
Old 02-23-2019, 05:33 PM   #13
Rewards Points: 110
When I'm putting in the small tiles around the switch/outlet boxes, what should I apply the mastic with? Even the short side of my trowel is much too large.
Any advice on cutting glass backsplash better?-img_20190223_173030_1550961208446.jpg
Old 02-23-2019, 05:56 PM   #14
Rewards Points: 1,460
It’s not really that hard. Get that cover off with the traditional hammer and flat blade screwdriver...then spend 69 cents and buy a new one. As to applying the mastic, lets see.....your finger? Chunk of cardboard? Popsicle stick? Plastic fork? Same screw driver? Just put on the tile. All of those will be just and yeah, I’ve done this more than once.
Gymschu likes this.
ront02769 is online now   Reply With Quote
Old 02-23-2019, 06:11 PM   #15
JUSTA MEMBER
Rewards Points: 290
My choice, pop-sickle stick.
Have a few in the toolbox, convenient in many uses.
ED
Installing glass backsplash around outside corners Klawman Tiling, ceramics, marble 7 09-22-2015 02:21 AM
VCT Trick Design: Cutting and Install Advice Please steveroberts Flooring 0 08-15-2012 09:38 AM
Cutting glass mosiac daviddls12 Tiling, ceramics, marble 0 01-24-2012 12:32 PM
Glass Mosaic tile Question, cutting and grooved trowel ryan5068 Tiling, ceramics, marble 3 11-20-2011 11:33 AM
