Advice For Setting Ip Slab Of Concrete - Concrete, Stone & Masonry - Page 3 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree11Likes
Old 04-24-2019, 03:52 PM   #31
Rewards Points: 8
Re: Advice for setting ip slab of concrete
Originally Posted by Nealtw View Post
So that is above the level line on the wall and above the deck? yes.
That is not level pick up one end until the bubble is right dead centre between the two lines, that buddy, is the slope we wanted.
Hello here is a pic of what i am gonna start or is the slope to high. I know it is above the line level i took. Or should i drop the back piece more to the slab to get it even in hight. I just want to make sure the run off does not go into my foundation
Sent from my LGLS676 using Tapatalk
chris3178 is offline   Reply With Quote
Old 04-24-2019, 04:01 PM   #32
retired framer
Rewards Points: 14,708
Set your level right next to that board and take a picture of the bubble.
The most you need is 1/2 inch slope from the wall to the concrete.
Do not use flat bottom gables with scissor trusses.
Old 04-24-2019, 04:48 PM   #33
retired framer
I think your line is above the height of the deck like in picture 1. and you would just do concrete to that line.
If you want more slope just raise the line on the wall but taper the ends down so you are not creating a tripping hazard.
See in picture 2, the slope just changes for a few feet at the end.
Resurfacing & Extending Backyard Concrete Slab WharfRat Concrete, Stone & Masonry 1 06-18-2016 09:34 PM
Concrete Basics for the DIYer Mort Concrete, Stone & Masonry 7 11-22-2012 11:19 AM
Cement backer board over kitchen concrete slab gtimk4 Flooring 2 02-19-2012 02:46 PM
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 12:17 PM
