Advice For Setting Ip Slab Of Concrete - Concrete, Stone & Masonry - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree11Likes
Old 04-09-2019, 08:15 PM   #16
Rewards Points: 8
Re: Advice for setting ip slab of concrete
Hello i did try and get that measured but i couldn't get to it as it was pouring out but i could tell u that the dirt that is under the bump out it is all uneven. So for me to even try and get a mesurement then to strick a line i think it would be off.and to see if it is going away from house. So my best bet would be to a
Flatten the dirt i have there get it all level and add about 1 inch to 2 inch more of dirt to bring the slab to 3 inch not all 5 inch of cement. I just look at the old slab and im like i keep thinking that in order for me to get the slope to run off that hight the back end of it would have to be raised up to like 6 or 7 inch correct me if im wrong. Also can i lay a full level slab first to get it to match the old slab let it dry then come back and add a lil slope on top of the finished slab so the run off is still going away from house.
Sent from my LGLS676 using Tapatalk
chris3178 is offline   Reply With Quote
Old 04-09-2019, 08:49 PM   #17
retired framer
Rewards Points: 14,748
You are putting line on the wall level with the concrete on the right,
That is above the dirt by about 5 inches. Then you will check if there is a slope with one end of the level sitting on that line and on the concrete on the end of the patio.
No dirt involved. Is the concrete patio higher or lower than the line?
Do not use flat bottom gables with scissor trusses.
Old 04-10-2019, 06:15 AM   #18
Property Mgt/Maint
Rewards Points: 6,048
Bad idea.
You want full depth, all done in a single pour.
Your slab should have about 2 -3" min of crushed stone under it, compacted. Don't use top soil to back fill, Use stone. The new top of slab height will be controlled by your forms. So it is important to get them right prior to pour day. I would also put some rebar mesh in there, and also use expansion joint mat'l along the house wall and also to separate your existing concrete.
landfillwizard likes this.
[political signature removed]
Yodaman is offline   Reply With Quote
Old 04-10-2019, 06:39 PM   #19
Rewards Points: 8
I will get a line stricked tomorrow then level it to see if it grades away from house
Nealtw likes this.
Old 04-13-2019, 03:24 PM   #20
Rewards Points: 8
Hello finely got to do my line level. Here is a pic of it. The bubble is sloped towards my foundation a lil so i have to grade it the other way.
Old 04-13-2019, 03:31 PM   #21
retired framer
Hello finely got to do my line level. Here is a pic of it. It looks like it is on the level side.
So that is above the level line on the wall and above the deck? yes.
That is not level pick up one end until the bubble is right dead centre between the two lines, that buddy, is the slope we wanted.
Old 04-13-2019, 03:49 PM   #22
retired framer
Something like this.
Old 04-13-2019, 04:28 PM   #23
Rewards Points: 8
Ok if i raise the end that is on the cement it will be level. So is i thought i wanted it sloped away from house alil not level.
Old 04-13-2019, 04:47 PM   #24
retired framer
You held the level showing the slope. It is not level until the bubble is dead centre, so if you do that again and pick up the end until the bubble is in the middle, you will be more than 1/4" under that end of the level and that is lots for what you have.
Old 04-13-2019, 05:08 PM   #25
Rewards Points: 2,084
why ANY wire in an exterior 4" think piece of conc ? that's not in any recommended spec i've ever seen,,, to add any benefit, it must be set @ the vert plane midpoint & allowable +/- is 2%,,, that = .1",,, no one's that good - i see proof of that every day,,, if only 1/2 of these conc jabonies knew what & why, we'd have MUCH less work,,, come to think of it, suppose we should buy 'em beer
as posted by the op, this job's only 65b @ 80# conc - easy enough for 1 guy to do - 3 saturdays & still have time for been
the line level looks fine on 4'6' as he wants wtr to run AWAY from his home, right ?
Nealtw likes this.
Old 04-13-2019, 05:26 PM   #26
Rewards Points: 8
Hello stadry that is correct i want to slope away from house. I am on here just trying to get it right thats all i want i know i am capable of doing this job just the want to get it right so i dont have any problems
Old 04-13-2019, 05:43 PM   #27
retired framer
Old 04-13-2019, 06:01 PM   #28
somebody tell him that's not wtr inside the vial or carpenters would never work when its below 32f
Nealtw likes this.
Old 04-14-2019, 04:39 AM   #29
so far all we've talked about is stripping sod, string line, forming, mesh ( or not ), & using a level but nothing about wtr/cement ratio, mixing, placing, & finishing which's where the real $$ are found
tell you what i'd do - i'd get all this other stuff done even place forms / into 3rds,,, then i'd go to my local south-of-the-border job ctr & hire a conc finisher,,, there's no shame in learning from a pro,,, that's where i learned most of my stuff,,, if you've f'd up somehow, he can fix it
if you're lucky enough to live in a sanctuary city, county, or state, it won't cost as much as if you didn't because there'll be a much larger inventory from which to choose help( couldn't he'p that last part )
Old 04-15-2019, 09:34 AM   #30
Rewards Points: 8
Hopefully i will get my framing set up and i will post pics of how it looks.im gonna use 1x4.
Yodaman likes this.
Resurfacing & Extending Backyard Concrete Slab WharfRat Concrete, Stone & Masonry 1 06-18-2016 09:34 PM
Concrete Basics for the DIYer Mort Concrete, Stone & Masonry 7 11-22-2012 11:19 AM
Cement backer board over kitchen concrete slab gtimk4 Flooring 2 02-19-2012 02:46 PM
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 12:17 PM
