Advice For Setting Ip Slab Of Concrete - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree11Likes
Old 04-08-2019, 06:06 PM   #1
Rewards Points: 8
Advice for setting ip slab of concrete
Hello i have a concrete slab in my backyard i want to add to it and also slope it away from my foundation. I got prices and they are on the 2000-3000 for the area i want so i looked it up and i was wondering if this is something a diy can do.the area im looking to fill is
23ft x 4ft 6in x 5 inch deep so it will match the old slab.im looking to fill area under house. Also how many bags of concrete would i need. Any advice would be great.
Pics attached
Sent from my LGLS676 using Tapatalk
chris3178 is offline   Reply With Quote
Old 04-08-2019, 06:10 PM   #2
Rewards Points: 312
Re: Advice for setting ip slab of concrete
you planning on driving or parking something heavy on it? 5" thick is overkill. 3.5 - 4" for a sitting patio is sufficient. and, yes, its a good DIY project. watch a couple youtube videos on how to get the pitch and set the forms...
use this site to get # bags:
https://www.quikrete.com/calculator/...w_wcB#concrete
Bondo and Johnny_inFL like this.
KPDMinc is offline   Reply With Quote
Old 04-08-2019, 06:17 PM   #3
retired framer
Rewards Points: 17,368
Are we just talking about the space below the bump out wall?
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Old 04-08-2019, 06:20 PM   #4
Rewards Points: 19,120
Google concrete calculator if you want to know how many bags it will take.
No way would I DIY this, there's way more to it then it looks like.
Do you own a cement mixer, bull float, plate compactor?
I've seen way to many DIY slabs done wrong.
Old 04-08-2019, 06:25 PM   #5
retired framer
plate compactor, might be a problem under a bump out.
figure 7-14
Old 04-08-2019, 06:33 PM   #6
Property Mgt/Maint
Rewards Points: 8,210
I would do it, but sure wouldn't be mixing by the bag. Possibly bring in sand, gravel and buy bags of portland. But more than likely I would bring in a custom mix truck. You need just under 1 1/2 yards at 4" depth.
The plus side here is that 4.5' wide is relatively easy to screed and finish.
[political signature removed]
Yodaman is offline   Reply With Quote
Old 04-08-2019, 06:34 PM   #7
Rewards Points: 11,072
Sure you can DIY.
But the way the post is worded makes me wonder if this is supposed to be a fix for a water intrusion problem. If so, it will help, but would make it more expensive when you finally decide to attack the root problem.
MTN REMODEL LLC likes this.
SPS-1 is online now   Reply With Quote
Old 04-08-2019, 06:39 PM   #8
Rewards Points: 3,286
Do you have any helpers, preferably one or two who have done concrete before? Definitely want a mixer, it will be about 80 sixty pound bags and that would be for 4" thick. 50% more if you want 6".
Having help is important as once you start you want to finish and while one person is mixing another can be troweling out what has been poured.
And don't forget the soda and hotdogs.
Bud.
Beer would be after it is done if desired.
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is online now   Reply With Quote
Old 04-09-2019, 05:06 AM   #9
Rewards Points: 8
Hello thanx for all your answers. I just took the measurement off the slab im adding to i can always add rock or stone or dirt. To bring up the measurement closer to 4 inch depth.
Yes it is the bump out that im trying to cover up and also add to my original slab. There is no water penetration issues that i know my bsmt is finished. I noticed the original slab os graded toward my house so i kinda thought to add this new slab and grade it away from house so water penetration don't happen in the future cause it hasn't happened yet.
Old 04-09-2019, 06:20 AM   #10
retired framer
measure down at both ends of the bump out and snap a line with a chalk line, then check the level at the end of your patio.
figure 7-14
Old 04-09-2019, 07:36 AM   #11
Rewards Points: 8
The red mark u made is the level and the black line is what my chalk line i measured is from the top of the bump out to the hight of the slab i want to make? Is that checking level or grade towards slab? I am asking cause the dirt is bumpy no level i was gonna level that area in preparing for the work but i do want a lil grade away from house
Old 04-09-2019, 07:48 AM   #12
retired framer
You want to check from the chalk line to the concrete just to see if there is a slope there already. If there is a slope there it is easy and if not then some more thinking to do. So check that first.
figure 7-14
Old 04-09-2019, 08:13 AM   #13
Rewards Points: 8
Ok gotcha i will do that when i get home and get back to you
Old 04-09-2019, 08:25 AM   #14
Rewards Points: 4,990
No way would I ask friends to help haul 80 60-lb bags of concrete.
huesmann is offline   Reply With Quote
Old 04-09-2019, 09:59 AM   #15
Rewards Points: 3,614
since you'll have 2 joints, that's 3 pours of 80# b - easy enough to diy
Resurfacing & Extending Backyard Concrete Slab WharfRat Concrete, Stone & Masonry 1 06-18-2016 09:34 PM
Concrete Basics for the DIYer Mort Concrete, Stone & Masonry 7 11-22-2012 11:19 AM
Cement backer board over kitchen concrete slab gtimk4 Flooring 2 02-19-2012 02:46 PM
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 12:17 PM
