DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Concrete, Stone & Masonry (https://www.diychatroom.com/f105/)
-   -   Advice for setting ip slab of concrete (https://www.diychatroom.com/f105/advice-setting-ip-slab-concrete-656969/)
chris3178 04-08-2019 06:06 PM
Hello i have a concrete slab in my backyard i want to add to it and also slope it away from my foundation. I got prices and they are on the 2000-3000 for the area i want so i looked it up and i was wondering if this is something a diy can do.the area im looking to fill is
23ft x 4ft 6in x 5 inch deep so it will match the old slab.im looking to fill area under house. Also how many bags of concrete would i need. Any advice would be great.
Pics attached
https://uploads.tapatalk-cdn.com/201...0d3e24ad94.jpghttps://uploads.tapatalk-cdn.com/201...5b34269a49.jpghttps://uploads.tapatalk-cdn.com/201...b7449b1e20.jpghttps://uploads.tapatalk-cdn.com/201...70db136b6c.jpg
Sent from my LGLS676 using Tapatalk
KPDMinc 04-08-2019 06:10 PM
Re: Advice for setting ip slab of concrete
you planning on driving or parking something heavy on it? 5" thick is overkill. 3.5 - 4" for a sitting patio is sufficient. and, yes, its a good DIY project. watch a couple youtube videos on how to get the pitch and set the forms...
use this site to get # bags:
https://www.quikrete.com/calculator/...w_wcB#concrete
Nealtw 04-08-2019 06:17 PM
Are we just talking about the space below the bump out wall?
joecaption 04-08-2019 06:20 PM
Google concrete calculator if you want to know how many bags it will take.
No way would I DIY this, there's way more to it then it looks like.
Do you own a cement mixer, bull float, plate compactor?
I've seen way to many DIY slabs done wrong.
Nealtw 04-08-2019 06:25 PM
plate compactor, might be a problem under a bump out. :wink2:
Yodaman 04-08-2019 06:33 PM
I would do it, but sure wouldn't be mixing by the bag. Possibly bring in sand, gravel and buy bags of portland. But more than likely I would bring in a custom mix truck. You need just under 1 1/2 yards at 4" depth.
The plus side here is that 4.5' wide is relatively easy to screed and finish.
SPS-1 04-08-2019 06:34 PM
Sure you can DIY.
But the way the post is worded makes me wonder if this is supposed to be a fix for a water intrusion problem. If so, it will help, but would make it more expensive when you finally decide to attack the root problem.
Bud9051 04-08-2019 06:39 PM
Do you have any helpers, preferably one or two who have done concrete before? Definitely want a mixer, it will be about 80 sixty pound bags and that would be for 4" thick. 50% more if you want 6".
Having help is important as once you start you want to finish and while one person is mixing another can be troweling out what has been poured.
And don't forget the soda and hotdogs.
Bud.
Beer would be after it is done if desired.
chris3178 04-09-2019 05:06 AM
Hello thanx for all your answers. I just took the measurement off the slab im adding to i can always add rock or stone or dirt. To bring up the measurement closer to 4 inch depth.
Yes it is the bump out that im trying to cover up and also add to my original slab. There is no water penetration issues that i know my bsmt is finished. I noticed the original slab os graded toward my house so i kinda thought to add this new slab and grade it away from house so water penetration don't happen in the future cause it hasn't happened yet.
Nealtw 04-09-2019 06:20 AM
1 Attachment(s)
measure down at both ends of the bump out and snap a line with a chalk line, then check the level at the end of your patio.
chris3178 04-09-2019 07:36 AM
The red mark u made is the level and the black line is what my chalk line i measured is from the top of the bump out to the hight of the slab i want to make? Is that checking level or grade towards slab? I am asking cause the dirt is bumpy no level i was gonna level that area in preparing for the work but i do want a lil grade away from house
Nealtw 04-09-2019 07:48 AM
You want to check from the chalk line to the concrete just to see if there is a slope there already. If there is a slope there it is easy and if not then some more thinking to do. So check that first.
chris3178 04-09-2019 08:13 AM
Ok gotcha i will do that when i get home and get back to you
huesmann 04-09-2019 08:25 AM
No way would I ask friends to help haul 80 60-lb bags of concrete.
stadry 04-09-2019 09:59 AM
since you'll have 2 joints, that's 3 pours of 80# b - easy enough to diy
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
