Adding Support To Concrete Wall For Granite Top - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree1Likes
  • 1 Post By Nealtw
Old 04-09-2019, 08:28 AM   #1
Rewards Points: 204
Adding support to concrete wall for granite top
I am looking at building a pavilion with concrete walls columns (see attached pic). What I want to do is extend the short walls on each side of the pavilion to be about 8 ft long, and then add granite for counter/bar top. My issue is that the concrete is apx 5ft tall, so I can't add the granite to top of the wall. What I was thinking of doing is bumping put the concrete blocks about 40" up the wall, so the granite can be place on there (vs making the entire wall double thickness). Curious about the support though. Can the concrete block bump out like 8-12" and still support granite top? Looking for some suggestions/advice.
Thanks,
rambo1224 is offline   Reply With Quote
Old 04-09-2019, 08:44 AM   #2
retired framer
Rewards Points: 4,576
Re: Adding support to concrete wall for granite top
Build a cantilever in the concrete wall.
Do not use flat bottom gables with scissor trusses.
Old 04-09-2019, 09:05 AM   #3
Rewards Points: 204
Thanks. So the cantilever is built into the wall so the only thing you see sticking out is the shelf that the granite would sit on?
Old 04-09-2019, 09:15 AM   #4
retired framer
You might get to the same place with just a steal shelf bolted to the concrete. Some of it would be seen from a distance or if you are short.
https://www.countertopbracket.com/Co...teel-p/fmp.htm
Old 04-09-2019, 09:29 AM   #5
Rewards Points: 1,784
If you're gonna use brackets like Neal linked, you should embed your fasteners (probably some kind of threaded insert?) in the concrete when you pour your columns.
huesmann is online now   Reply With Quote
Old 04-09-2019, 09:30 AM   #6
Rewards Points: 204
Thanks. Besides steel or cantilever, could I offset a row of the concrete block (40" up the wall), so there is enough overhang for the granite to lay on? Wasn't sure how much I could offset it by for it to have enough strength to support the granite
Old 04-09-2019, 09:40 AM   #7
retired framer
I don't have enough experience to comment on block, usually they put plywood under the granite and that would be bolted down.
But you need a block guy for better info.
Old 04-09-2019, 10:56 AM   #8
Rewards Points: 2,738
you could but it'll eventually fall off/down UNLESS its attached to steel reinforced full-height invisible columns ino,,, hate paying for the same ground 2x
stadry is online now   Reply With Quote
Old 04-09-2019, 02:58 PM   #9
Hammered Thumb
Rewards Points: 738
Maybe give a little more info, like a sketch. You're building poured concrete, or all CMU? How wide is the counter? 24" open below with no supports desired, or 18" wide bar height? With the granite, since its not mechanically fastened, the amount of unsupported overhang will be determined by the width of the support.
3onthetree is offline   Reply With Quote
Old 04-10-2019, 10:48 AM   #10
I believe that plywood-under-granite is an east coast vs. west coast thing. On the west coast they use a plywood support. Here on the east coast they use a thicker slab and no plywood underneath.
Old 04-10-2019, 10:57 AM   #11
retired framer
I guess you work with whats available.
Old 04-10-2019, 01:17 PM   #12
Hammered Thumb
Rewards Points: 738
Here in middle America we too use plywood backer when inside, but outside may not be the best idea.
Old 04-10-2019, 01:19 PM   #13
retired framer
Does your granite leak?
3onthetree likes this.
Old 04-11-2019, 08:32 AM   #14
Out of curiosity, how do the "plywood backing" folks mount undermount sinks? Over here they make cuts in the bottom of the slab and screw the clips into the cuts, with the clip right on the flange. Do y'all screw to the slab, or to the ply, using a spacer (or maybe a clip with a vertical extension) against the flange?
Concrete retaining wall crack and bowing - How to anchor? homeowner_101 Concrete, Stone & Masonry 24 12-15-2015 05:29 PM
How to insulate 1' concrete wall that meets 8' studded wall Truth Insulation 7 01-16-2012 09:14 PM
Seal Siding to Concrete Wall? stevex Building & Construction 3 08-07-2011 07:46 AM
Drywall on interior concrete basement wall marlenec Drywall & Plaster 1 07-18-2011 11:22 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
