2 Ft Stone Retaining Wall- Concrete Footing Or Gravel? - Concrete, Stone & Masonry - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 10-23-2015, 11:41 PM   #16
Rewards Points: 16
Originally Posted by barnabas131 View Post
the second one is exactly what im refferring too. the Portland stuff ive never used but would probably work just fine. For the size your doing you will want to buy in bulk anyway but if your limited to home depot i ahve used this: http://www.homedepot.com/p/Unbranded...8000/100343385
Play sand is a HUGE NO NO, the concrete washed sand you want to be as uncompacted as possible when layed, the weight of the stones and you doing any adjustments to level them will be all the compacting it needs. it will allow everything to sit perfectly flat and level.
That link is my local place so bulk is available
Thanks for the responses
lobsterbib is offline   Reply With Quote
Old 10-23-2015, 11:48 PM   #17
Rewards Points: 82
Id use this for base : http://www.buriensandandgravel.com/5-8-crushed-rock/
And this for french drain/backfill on wall : http://www.buriensandandgravel.com/5-8-clean/
And can use this: http://www.vulcanmaterials.com/const...ion-aggregates to figure out how much of each product you need
For density use 2000 lbs per cubic yard
barnabas131 is offline   Reply With Quote
Old 10-24-2015, 12:26 AM   #18
Rewards Points: 16
I already have 5/8 clean and started to fill by base
If I use that and top it w/ concrete sand, will that compact to be stable enough?
Old 10-24-2015, 12:51 AM   #19
Rewards Points: 82
the clean just has nothing to fill the voids. the base should be fully compacted before putting the sand on the sand is just enough to make it perfectly flat its hard to get it perfect with gravel. for your size wall if you already started with the clean i wouldnt go back now. lay it down and compact it every 2inches till its full thickness then lay sand and block
Old 10-24-2015, 12:53 AM   #20
Rewards Points: 16
Ok thanks
surface drainage above a retaining wall Benjamin5 Landscaping & Lawn Care 4 09-26-2015 03:44 PM
Help with retaining wall mold problems -- running out of ideas and in need of help! gottalearn Concrete, Stone & Masonry 17 11-03-2014 07:34 AM
Please help with retaining wall / patio issue that has arisen. coderguy Landscaping & Lawn Care 3 05-26-2012 05:45 PM
Retaining wall combining concrete blocks and PT lumber JEL Landscaping & Lawn Care 1 04-06-2012 09:39 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
