149 Year Old House Foundation... - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-18-2016, 08:35 PM   #1
Rewards Points: 4
149 year old house foundation...
hello i am from new jersey, i have a 149 year old home that has a foundation problem. the rear is old cement solid block. i injected the one crack that had not penetrated all the way through with quikrete commercial grade fastset epoxy anchoring via caulk gun, and then used type M motar to cover the injection area.
my problem lies within the area next to it, the cement block(solid cement block) is disintegrated, i was literally brushing it away with my metal wire brush, paying someone is no option here... i am cut out to do the work i just need to figure out how to go about this.... do i mix up a batch of concrete and clean the area and apply and form with plywood pressed against foundation?
im already going to be reinforcing the existing joists in the crawl space with house jacks and timber.
ill be uploading pics in a few minutes. thanks
and admins if this is in the wrong area i am sorry i did not read the rules.
su - is offline   Reply With Quote
Old 05-18-2016, 08:36 PM   #2
Rewards Points: 4
Re: 149 year old house foundation...
also forgot to mention, the cement block is resting on redbrick when i went down 18" with my trowel.
Replacing entire foundation after duplex house lift Subsidencehome Concrete, Stone & Masonry 7 04-19-2014 10:35 AM
Looking To Buy A 100 Year Old House...Some Problems Medic-5150 Building & Construction 3 09-24-2011 09:57 PM
Should I bolt my tri-level house to the foundation? SeattleDuck Building & Construction 2 10-16-2009 04:50 PM
My new project, 31 year old house... Axhammer General DIY Discussions 3 04-08-2009 08:46 AM
