Smart Home Technology - Windows and Doors - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By barnettnce
  • 1 Post By NickTheGreat
  • 1 Post By CaptTom
Old 04-25-2019, 06:09 AM   #1
Rewards Points: 58
While considering going to a smart house which type of technology do you ponder is best and would spend your money in and why? If you are familiar with any please share your ideas. Thanks.
marykinney likes this.
barnettnce is offline   Reply With Quote
Old 04-25-2019, 10:41 AM   #2
Rewards Points: 1,676
Re: Smart Home Technology
It's interesting, but not sure what it has to do with windows and doors, unless you're talking about some kind of smart locks, or smart alarm system.
huesmann is offline   Reply With Quote
Old 04-25-2019, 11:32 AM   #3
Knows Enough to be Danger
Rewards Points: 1,249
In what way? I have a lot of smart home stuff, but not much in the "window and door" department, save for a few open/closed sensors
Though one thing soon on my list is a programmable lock. I like the idea of restricting certain people at certain times
NickTheGreat is online now   Reply With Quote
Old 04-25-2019, 06:41 PM   #4
Rewards Points: 2,534
I think there are many different valid answers. It all depends on wheat you want to do.
Some folks like to be able to say "Alexa, dim the lights" or "start the coffee maker."
Some folks are audiophiles who like to pipe the music to every room, or TV enthusiasts who automate their home theater.
Some folks like to use "presence detection." Like have lights and doors operate automatically when they enter or leave the house, or a room. Believe it or not, there are occupancy sensors for beds and even some sort of smart toothbrush.
My thing is monitoring. I want to know the temperature of a couple of spaces that have water pipes running through them. That allows me to adjust the thermostats so it's just warm enough not to freeze, but not waste a lot of energy. Then I found I could also monitor my existing Honeywell thermostats. Next I'm working on being able to monitor when each heating or cooling zone comes on and off, as well as the burner on the boiler. This should give me good data I can correlate to fuel usage and climate data.
One big decision is whose "hub" you want all these devices to talk to. Most of these use a cloud-based system, like my thermostats. The app doesn't change the thermostat. It sends a request to the Honeywell servers (if the internet isn't down) to send a request back to the thermostat. Likewise with SmartThings and most other brands. They all want to be "in the loop" between you and your devices.
I don't like that model, so I'm using an open source product called Home Assistant on a Raspberry Pi device. Everything is local, although I can connect to it remotely. OpenHAB is another similar project, I tried them both and it was almost a coin-flip to pick one. There are also commercial "local control" hubs.
The next thing to choose is the protocol to connect to the devices. There are lots of IP based options, but many of those are also programmed to "phone home" rather than allow direct connection. With some (like Sonoff devices) you can flash the firmware to install an open operating system, but that gets pretty technical.
The two most common other protocols are Zigbee and Z-Wave. Both are just a wireless alternative to regular WiFi, and both are widely available and supportable from many different hubs. I'm using a number of Zigbee door/temperature sensors, as well as a SmartThings Zigbee smart plug, without issue. I just inserted a USB hub in the Raspberry Pi and Home Assistant detected and used all these devices.
CaptTom is offline   Reply With Quote
1938 TN Home - My First Home, My First project, Tons of Pictures!!! Firefighter3244 Project Showcase 78 07-01-2014 11:55 PM
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 08:42 PM
Owning a home (not a mobile home) on leased land? Badfish740 Off Topic 11 03-30-2008 10:34 AM
A facelift for your home Grumpy Remodeling 0 07-07-2004 08:43 PM
