Sliding Screen Door - Problem Removing - Windows and Doors - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By Nealtw
  • 1 Post By mitchmcc
  • 1 Post By Nealtw
Old 06-29-2020, 04:16 PM   #1
Rewards Points: 6
Sliding screen door - problem removing
Hi
I need to remove a screen door to replace the screen. I've seen a number of videos explaining how to adjust the tension screws but I'm pretty sure my door doesn't have those screws. How do I get the door out of its tracks if there are no tension screws??
Mitch
mitchmcc is offline   Reply With Quote
Old 06-29-2020, 04:24 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 13,246
Re: Sliding screen door - problem removing
Post some pictures as you get more posts. You'll need like 5 posts.
Old 06-29-2020, 05:23 PM   #3
Rewards Points: 6
Thanks for the suggestion. Apparently I can't post these portrain, only landscape. First one shows the bottom of the door on metal runner. The other two are the top of the door showing the spring that (should) close the door.
Sliding screen door - problem removing-door-1.jpg   Sliding screen door - problem removing-door-3.jpg   Sliding screen door - problem removing-door-4.jpg
Old 06-29-2020, 11:35 PM   #4
Rewards Points: 1,737
I would slide the door all the way one way and look for screws that go straight up in that head track, and remove them. Then slide the door all the other way and remove the rest of them. Then unhook the spring. That head track should pop out. You might have to give it a whack with a thin stiff putty knife and a hammer if it's been glued on with varnish.
If there are no screws in the head track, let us know.
XSleeper is offline   Reply With Quote
Old 06-29-2020, 11:46 PM   #5
retired framer
Rewards Points: 15,284
No screw in there?
Windows on Wash likes this.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Nealtw is offline   Reply With Quote
Old 06-30-2020, 12:33 AM   #6
That's the top of the door Neal. No roller up there.
Old 06-30-2020, 12:36 AM   #7
retired framer
The bottom looks similar.
figure 7-14
Old 07-01-2020, 09:40 PM   #8
Rewards Points: 6
No - no screw in that little hole. I think the suggestion to take the top track off completely is probably right. That's what I was thinking but didn't want to do that if it wasn't necessary. (My DIY skills are not up to much and things I take apart don't always go back together again!!)
I'll give this a go at the weekend.
Thanks for your help
Nealtw likes this.
Old 07-01-2020, 10:33 PM   #9
retired framer
Take 2 pictures of every step you take before and after.
mitchmcc likes this.
figure 7-14
