Sliding Glass Door Replacment - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 10-11-2018, 01:20 PM   #1
Rewards Points: 352
Question
Looking to replace my very old single pane sliding glass doors. Having a dilemma on which type of door would work best as the siding trim has been wrapped onto the siding frame on the exterior.
I guess my question is would I better off to remove that siding trim entirely using a door frame with a nail fin/flange or could I get away with keeping some of the trim in tact and opt for a typical box frame? I have no problem removing the trim, replacing with Aztec/PVC just don't wanna kick myself if I was able to slide the new frame and keep some existing trim.
I attached a few pic's of my setup. Thanks in advance for your time and help!
cbaur88 is offline   Reply With Quote
Old 10-11-2018, 10:40 PM   #2
firehawkmph's Avatar
Rewards Points: 2,550
Re: Sliding Glass Door Replacment
I had a similar situation on my own house when I replaced my old slider with a new Andersen unit. I took off the vinyl siding around the door area to expose everything. Installed the new door which had a nailing flange. After sealing with protector wrap, drip cap, etc., I used 1 x 4 pvc trim to trim out the door. Installed some new J-channel around the pvc and reinstalled the siding. Makes for a nice job and in my opinion, easier when it's all said and done.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Help with sliding glass doors. ob2s Windows and Doors 8 05-30-2012 09:54 AM
sliding woodframe glass doors stephenbishop Windows and Doors 1 03-13-2012 08:11 AM
Pella sliding glass door trim seperated from glass Scuba_Dave Building & Construction 6 03-10-2011 01:28 PM
Moulding Around Sliding Glass Door JRMN Building & Construction 8 08-03-2010 12:22 PM
Replacing Sliding Glass Door w/ French Doors zapatero3 Remodeling 1 07-15-2010 06:01 AM
