Replacing Interior Doors - Windows and Doors - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 2 Post By Nealtw
  • 1 Post By Nealtw
  • 1 Post By 660catman
Old 10-30-2019, 02:51 PM   #1
Rewards Points: 108
Replacing interior doors
I'm replacing these interior doors (old door pictured). The old doors are 78 7/8".
All doors at store are 80".
It seems like there would be just a hair of clearance for the door to swing if it were 80". Is this my only option? And trim some off if there's not enough room vertically?
farmerjohn1324 is online now   Reply With Quote
Old 10-30-2019, 03:20 PM   #2
retired framer
Rewards Points: 40
Re: Replacing interior doors
Cutting 2" off the door would be standard practice. If you were remodelling you would adjust the framing for the new height.
Do not use flat bottom gables with scissor trusses.
Old 10-30-2019, 03:49 PM   #3
Rewards Points: 108
Too bad my table saw is in storage. And not even sure what container it's in.
Old 10-30-2019, 04:07 PM   #4
Rewards Points: 4
All I did was clamp a straightedge to door and cut with circular saw. Make sure straightedge has a little bit of height to it so saw can’t “jump” onto it while cutting.
Retired guy from Southern Manitoba, Canada.
660catman is online now   Reply With Quote
Old 10-30-2019, 04:08 PM   #5
retired framer
Rewards Points: 40
Tape the door where the cut will be. Clamp a board to the door to use for a fence to run the saw against and have a nice finish blade in the saw.
Some people do a surface cut with a knife just next the saw cut first to limit the tear up too.
Old 10-30-2019, 04:11 PM   #6
Rewards Points: 108
For a table saw?
Old 10-30-2019, 04:21 PM   #7
retired framer
Rewards Points: 40
For a table saw?
circular saw.
SeniorSitizen and timkoupe like this.
Old 10-30-2019, 04:27 PM   #8
Rewards Points: 108
For a table saw?
circular saw.
Ok.
Maybe I'll practice that with some plywood first.
Old 10-30-2019, 04:34 PM   #9
retired framer
Rewards Points: 40
Ok.
Good plan. Everyone should have jigs like the video, one 8 ft and one a little more than 4 ft.
timkoupe likes this.
Old 10-31-2019, 08:31 AM   #10
Rewards Points: 408
I mean, if the edge at the bottom of the door isn't quite straight, few people will notice or care.
huesmann is offline   Reply With Quote
Old 10-31-2019, 06:58 PM   #11
Rewards Points: 136
Use many tooth saw blades for cleanest cuts. Before you cut the new doors, it may pay to hang the old doors and see what kind of cuts you need and if lock holes and hinge cuts will line up. What kind of gaps. How much gap under the door you had and can have with new doors.
carpdad is offline   Reply With Quote
Old 10-31-2019, 07:19 PM   #12
retired framer
Rewards Points: 40
It might be a little trick to hang it first before cutting.
Old 10-31-2019, 07:26 PM   #13
Rewards Points: 4
I take it you’re buying slab doors where you need to do all the work to? I did a total house Reno and installed slabs in existing frames. I laid old door on new one and traced all places to cut length, mitre hinges, drill for door handles. I had jug for cutting for handles. Way nicer. Glad I did that as bathroom door was not square on top.
Nealtw likes this.
Old 11-08-2019, 12:50 PM   #14
Rewards Points: 108
Is this blade good to cut with? I know there's enough teeth but is it burned or something? Would it leave marks on the door? I think it got burned it from cutting some sagging plywood.
Old 11-08-2019, 12:55 PM   #15
retired framer
Rewards Points: 40
Teeth are bent just a little to make the cut a little wider than the blade. When you over heat a blade they can loose the set or bend, try it on a piece of plywood and see how it cuts.
