PVC Sliding Patio Door....Is This Normal? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 01-01-2018, 05:39 PM   #1
Rewards Points: 1,332
PVC sliding patio door....Is this normal?
Hello all
I'm remodeling my kitchen, and drywall has been pulled out
I noticed something that seems strange to me:
The patio door (sliding PVC - Jeld Wen apparently) is attached to the framing on the top with only 1 screw (on the right corner)
Should not it be secured with more than 1 screw?
If I need to add some more, which screws should I get?
french_guy is offline   Reply With Quote
Old 01-01-2018, 08:03 PM   #2
Rewards Points: 18,954
Re: PVC sliding patio door....Is this normal?
Post a picture so we can see what your seeing.
There should be no screws at the top, only in the jambs on the sides.
Old 01-01-2018, 08:13 PM   #3
Guapo
Rewards Points: 11,950
If you put more screws in the top of that door, it may take it out of level or plumb & might cause door problems.
Guap0_ is offline   Reply With Quote
Old 01-01-2018, 09:52 PM   #4
Rewards Points: 1,713
The door likely has a nailing fin and is attached to the exterior side of the wall with many fasteners. Can't say if your directions called for any along the jambs. Not many people follow directions anyway.
XSleeper is offline   Reply With Quote
Old 01-02-2018, 08:14 AM   #5
Guapo
The installers were probably near the end of the job & they figured that one screw in the top wouldn't hurt. Let's finish & go.
Old 01-02-2018, 08:18 AM   #6
retired framer
Rewards Points: 15,110
I agree with @XSleeper , it likely has a fin and the one screw was placed there to solve a fit problem.
Old 01-02-2018, 08:29 AM   #7
Rewards Points: 1,028
I just had two vinyl sliding doors removed and replaced with French doors . Both sliders had a nail flange on them . There was no indication of what brand they were but I would guess yours is the same .
Porsche986S is offline   Reply With Quote
Patio Sliding Door Glass is fogged up mjriley Windows and Doors 6 07-02-2016 07:05 AM
question about sliding folding patio doors Pawl Remodeling 1 11-07-2013 03:30 PM
question about installing sliding folding patio doors Pawl Remodeling 0 11-01-2013 05:01 PM
how to transform concrete patio into deck IsabellaS Landscaping & Lawn Care 5 07-04-2012 07:41 PM
Sliding patio door dinosaur1 Building & Construction 1 06-15-2011 01:40 PM
