Patio Door Removal - Windows and Doors - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By XSleeper
Old 09-15-2017, 02:11 PM   #1
Rewards Points: 56
patio door removal
need help removing swing patio door without damaging it. Most of it is the clad part. I think it is Andersen Windows by the lock info. Newer door glass has Andersen logo but not this one.
nauttboy is offline   Reply With Quote
Old 09-15-2017, 06:31 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 13,188
Re: patio door removal
https://parts.andersenwindows.com/re...eguide-0005105[1].pdf
Old 09-15-2017, 06:58 PM   #3
retired framer
Rewards Points: 15,110
Originally Posted by Windows on Wash View Post
404 PAGE NOT FOUND
Old 09-15-2017, 07:42 PM   #4
https://www.andersenwindows.com/~/me...de-0005420.pdf
The Following User Says Thank You to Windows on Wash For This Useful Post:
Nealtw (09-15-2017)
Old 09-16-2017, 08:41 PM   #5
Rewards Points: 56
Thanks for the link but I need the frame part.
Old 09-16-2017, 09:26 PM   #6
Rewards Points: 1,713
It surely has a nailing fin. The siding and j-channel would all need to come off to remove the nails from the nail fin.
The trim would come off on the inside. Carefully run a drywall saw around the rough opening to look for nails or screws through the jamb. Cut them with a Sawzall and short metal blade.
Then there may be sealant under the threshold. As you tip the door down from the outside, you would carefully pry under the door. (You should remove any long screws in the sill first).
You should also remove hinge screws and the operating panel.
Windows on Wash likes this.
XSleeper is offline   Reply With Quote
Old 09-17-2017, 10:20 AM   #7
You need to remove the whole thing?
If so, like @XSleeper said, pull the trim, cut through the nails, pull some of the hinge screws and see which ones go into the RO, and pull the door.
Old 09-17-2017, 09:46 PM   #8
Rewards Points: 56
Yes the whole thing. If i understand correctly. remove the door. remove trim. cut around the frame and stud. What about the other stationary door? removing the whole frame with attached door wood be heavy.
Question: are the fin for mounting purposes or water protection? Maybe both?
Old 09-17-2017, 10:20 PM   #9
Yes, both.
The fixed panel does not come out on a hinged unit. It will come out with the frame. If it's the passive side of a double door (if it has hinges) it has side bolts that hold it shut.
Patio with small retaining wall details.. freeclimbmtb Concrete, Stone & Masonry 0 08-08-2014 11:49 AM
Transition from a new pitched patio to an existing level patio barlav Concrete, Stone & Masonry 1 05-03-2013 05:20 AM
how to transform concrete patio into deck IsabellaS Landscaping & Lawn Care 5 07-04-2012 07:41 PM
Patio Cracked & Sinking silvabul Building & Construction 3 05-04-2011 09:53 AM
New Patio & Weep Screed Woes DeepDish Building & Construction 3 12-03-2006 08:11 AM
