Patio Door Glass - Replace Or Repair - Windows and Doors - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Canarywood1
Old 05-14-2019, 07:02 PM   #1
Rewards Points: 24
Patio Door glass - replace or repair
Sliding side glass has broken seal on 15 year old door. New thermal unit is $300 and complete new door about $650 with lifetime warranty. I would do the install/repair.
Which way would you go?
martik778 is offline   Reply With Quote
Old 05-14-2019, 07:16 PM   #2
Rewards Points: 4,026
Re: Patio Door glass - replace or repair
Given the age of the door, I would think other problems might be in the near future and would replace the whole thing.
stick\shift is offline   Reply With Quote
Old 05-14-2019, 07:40 PM   #3
retired framer
Rewards Points: 16,614
Often you find a very poor installation and pulling the door and doing it right might be the right thing to do and when you have a repair that will cost 1/2 of new, sounds like a good reason.
Do not use flat bottom gables with scissor trusses.
Old 05-14-2019, 07:54 PM   #4
Rewards Points: 1,004
You say lifetime warranty on the new door, what is the life of the new door??
Canarywood1 is offline   Reply With Quote
Old 05-14-2019, 07:55 PM   #5
retired framer
The door it at end of life when it leaks or some part breaks
Old 05-14-2019, 08:33 PM   #6
Rewards Points: 24
The slider was hard to close the last 5 years or so, did not quite line up with the slot due to building shifting. I think this may have causes premature failure of the seal.
Old 05-15-2019, 12:38 AM   #7
retired framer
Old 05-15-2019, 09:04 AM   #8
Rewards Points: 1,915
I would just bite the bullet and replace. That way you can fix the fit issues caused by the settling while you're at it (or at least keep up with the issues).
huesmann is offline   Reply With Quote
Old 05-15-2019, 10:55 AM   #9
Your a real ball of fire today Neal!
Nealtw likes this.
Seek Advice - Recharge, Repair or Replace Fujitsu Minisplit SanDiegoCool HVAC 2 05-10-2018 07:56 AM
Replace carpet or repair? J89Mike Flooring 4 01-30-2018 07:20 PM
soft spot at cross gable on roof. Can i repair or do i have to replace? rbooe05 Roofing/Siding 7 10-31-2017 02:33 PM
Repair or replace my older R22 unit AussieWendy HVAC 24 01-02-2014 04:19 PM
torch down roof repair or replace? ohmiahgod81 Roofing/Siding 2 09-23-2012 01:25 PM
