Old Rusty Garage Door Springs - Windows and Doors - DIY Chatroom Home Improvement Forum
Like Tree20Likes
Old 04-11-2019, 09:09 AM   #1
Rewards Points: 1,494
Old rusty garage door springs
People,
Double door, about 30 yrs old. Each side has 2 long coil springs. One split in two. never done this before, so should I replace all 4 now? Just that one?
Not sure how to order a new one, or where. Measure length while it is relaxed?
Note: they are not torsion springs. There is no such spring (s), just 2 on each side, going from front of door toward the back, just above the bracketry onto which the rollers travel.
Thanks.
papereater is offline   Reply With Quote
Old 04-11-2019, 10:28 AM   #2
Rewards Points: 526
Re: Old rusty garage door springs
I have no idea if or where you can get those springs. However...
30 years old...is your door wood? Take care, they are a lot heavier than you might realize. Had one and the cable clamp to the spring (or something, can't remember) broke on just one side. Good thing I wasn't directly under it when it came down. It came down with such force it broke 2 panes of the glass, and i'm surprised it didn't crack the concrete. To repair the cable I placed a clamp on inside of the roller track, one on each side, to block the rollers and prevent it from coming back down while I did the repair. Definitely did not get back under it during the repair and while it was clamped, just in case.
papereater and Tom153 like this.
ZEW496 is offline   Reply With Quote
The Following User Says Thank You to ZEW496 For This Useful Post:
papereater (04-11-2019)
Old 04-11-2019, 10:32 AM   #3
Big Thanks, Zew. It is steel, not wood. It was closed when the spring snapped so I just heard a loud Booooiiiiing! I did open it this morning by pushing the open button, helping it up with my arms a bit, went up OK. It is now up. Anyway, Maybe I should look around a bit for those springs. Hate to order a new door.
Just found out they are called extension springs (as opposed to the torsion type).
Tom153 likes this.
Old 04-11-2019, 10:34 AM   #4
Rewards Points: 6,487
They should be replaced in pairs. IF you have 4 total and they are all 30 years old, I would probably replace all 4,
You can buy them at Lowes https://www.lowes.com/search?searchT...e+door+springs and I'm sure HD has them also.
When in doubt about any spring I replace with the same gauge wire, length and number of coils. As you can see from the link above there is more than one choice and it is based on the weight of the door.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
The Following User Says Thank You to Colbyt For This Useful Post:
Old 04-11-2019, 10:34 AM   #5
retired framer
Rewards Points: 11,906
Originally Posted by papereater View Post
People,
Thanks.
They go by the height and weight of the door. And every company has a different colour code for the weight rating.
https://www.amazon.ca/Ideal-Security...99287670&psc=1
Dave Sal, papereater and Tom153 like this.
Do not use flat bottom gables with scissor trusses.
Nealtw is offline   Reply With Quote
The Following User Says Thank You to Nealtw For This Useful Post:
Old 04-11-2019, 11:10 AM   #6
Good to know all this, People! Learned so much already! Good thing it is not an emergency- I can leave door open at night.
Nealtw likes this.
Old 04-11-2019, 12:36 PM   #7
Probably a good plan. The plastic gears in the openers can't handle the weight very well without the spring balance.
What I forgot to say in the post above is just take one to the store with you and match it. That is what I did when I replaced it.
Be sure to install the safety cables that should come with it. A 30 year old opener may not have come with them but all the newer ones do. It greatly helps prevent property damage and decapitation when the spring breaks.
papereater likes this.
Colbyt
Old 04-11-2019, 01:26 PM   #8
Will have to study this safety cable. Also, the garage door opener is still an ancient/vintage Heathkit, probably made in 1980, or even earlier or so. Sheesh- they dont make them like that anymore.
Old 04-12-2019, 07:25 AM   #9
Going to HD to match up that broken spring today. What to you guys think about the fact that when my door shuts, and it approaches the ground ready to stop, it slams hard and loud onto the concrete floor. Would that be a sign that truly all the rusty springs are either too loose on the cable/pulley or worn out badly? I just thought of this now as I am replacing/repairing this spring.........
When a door shuts, shouldnt it touch the floor gently without a huge loud SLAM/BANG?
Old 04-12-2019, 10:09 AM   #10
If this was before the spring broke
I would say someone should have adjusted the spring tension to soften the close.
If after I would say it is 100% normal.
With the opener disconnected from the door a properly adjusted garage door should stop and hold in any position between 6" off the floor and fully open. You adjust the tension of the springs to achieve. this.
Colbyt
papereater (04-12-2019)
Old 04-12-2019, 10:11 AM   #11
Dave Sal's Avatar
Rewards Points: 718
My garage door closes quietly. Sounds like your springs don't have much tension left in them. Have you ever disconnected the opener from the door and tried to open it by hand? It should be relatively easy with the springs doing most of the work.
dd57chevy and papereater like this.
Dave Sal is offline   Reply With Quote
Old 04-12-2019, 10:17 AM   #12
Good test method, Davesal, and easy to do/verify. And colby, it happened (slamming) before spring broke. Good to know this stuff.
Old 04-12-2019, 10:23 AM   #13
Rewards Points: 1,934
I vote for replacing them all, frankly at 30 years old, you've gotten your money's worth out of them and it's not worth the hassle of a second visit down the road. You gotta pay to have the whole bar thing removed anyway so might as well.
We only replaced the one spring when ours broke because we were figuring that we'd buy a new garage door (and the springs are incompatible with the new door) in the next year or two - the second one hasn't gone out yet, but we won't be replacing the door this summer and now we are both constantly saying "hey it's summer, so if it snaps it won't be a big deal..." This small self-comfort will not hold water when winter returns, we're going to be worried about it breaking all winter >.<
(I'm not a professional, just a homeowner who dabbles in a bit of everything DIY)
Mystriss is offline   Reply With Quote
Old 04-12-2019, 10:46 AM   #14
A "Handy Husband"
rjniles's Avatar
Rewards Points: 356
If by 4 springs you mean 2 in parallel on each side, you can replace with a single pair with the correct weight limit. You need to weigh the door with the springs disconnected. Use a bath scale. Springs are sold by weight range.
Sent from my Moto E (4) Plus using Tapatalk
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 04-12-2019, 10:48 AM   #15
It's two separate doors so 4 springs in total
Converting garage attic into light storage space lixepoc Building & Construction 7 01-05-2018 12:45 PM
Garage feed before garage construction WillK Electrical 8 04-12-2017 09:26 AM
Installing 220 in garage for future welder - questions! wguttrid Electrical 7 01-31-2013 07:30 AM
Garage Roof Support & 2nd Floor Addition Info? olimits7 Building & Construction 3 10-15-2012 06:42 PM
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 10:32 PM
