Need Help Removing A Frozen Deadbolt - Windows and Doors - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By JoeyZ
  • 1 Post By huesmann
Old 08-08-2020, 04:48 PM   #1
Rewards Points: 34
Need help removing a frozen deadbolt
Hi all,
I've got a security door outside our bedroom door that's locking us in instead of locking others out!
The deadbolt won't turn. I've taken the "housing" off but still can't get it to budge. I've tried inserting a screwdriver and turning as well as trying to push the little lever above the hole but no luck so far.
I've attached pictures. It's a Quickset brand, just in case that helps.
Really trying to avoid having to hire someone to help, and also would like to avoid using a chemical to loosen it. I don't want to start pulling and bending until I know if that will help or make things worse.
Any suggestions would be greatly appreciated!
Thanks,
J
JoeyZ is offline   Reply With Quote
Old 08-08-2020, 05:01 PM   #2
dj3
Rewards Points: 300
Re: Need help removing a frozen deadbolt
Do you have the interior side of the handle?
It has a rod that goes in the hole in the latch body. Then when you rotate the handle 90* to the left, the latch goes in and unlocks the gate.
So this is what you have to do manually.
If you can't, bring in the beast: the sawzall, and cut the latch. Be careful not to damage the door or anything along the way, including yourself. A recip saw can have its own mind sometimes.
Good luck.
dj3 is online now   Reply With Quote
The Following User Says Thank You to dj3 For This Useful Post:
JoeyZ (08-09-2020)
Old 08-08-2020, 05:18 PM   #3
Rewards Points: 34
Good luck.
Thanks. I do have the handle. It wouldn't turn which is why I opened it up.
Hoping there's another way since I don't own a saw that will do the job.
Old 08-09-2020, 08:35 AM   #4
Rewards Points: 490
The handle won't rotate when you insert it into the hole, indicating the bolt itself is frozen up? Or the handle turns but the bolt doesn't turn, indicating you've rounded out the cam slot?
huesmann is offline   Reply With Quote
The Following User Says Thank You to huesmann For This Useful Post:
JoeyZ (08-09-2020)
Old 08-09-2020, 09:00 AM   #5
Rewards Points: 412
There are Quickset videos on line for this problem.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
JoeyZ (08-09-2020)
Old 08-09-2020, 02:47 PM   #6
Rewards Points: 34
Hmmm... I've watched a bunch of vids on youtube but haven't managed to find one that seemingly helps my situation.
The handle won't rotate at all, either using the lock handle, when I remove the housing and stick a screw driver in the hole, or when I try to push back the lever you see at the top of the mechanism. It appears to be frozen.
That's not to say I'm not doing something wrong.
Seems like I should be able to further disassemble the mechanism and remove this sucker.
Old 08-09-2020, 07:43 PM   #7
Rewards Points: 322
take a laarge flathead screwdriver. put it 90deg to that bracket (above the "up"), then hammer on the screwdriver close to the door.
Fix'n it is offline   Reply With Quote
The Following User Says Thank You to Fix'n it For This Useful Post:
JoeyZ (08-09-2020)
Old 08-09-2020, 08:05 PM   #8
Rewards Points: 34
Thank you. I just got it out.
A few hours ago I poured a bit of olive oil over the mechanism. After seeing your post I took a pair of locking pliers, attached it to that bracket, and pulled using my viking-like strength.
Thanks again to all that chimed in. I do appreciate it.
Fix'n it likes this.
Old 08-10-2020, 07:30 AM   #9
Rewards Points: 490
JoeyZ (08-10-2020)
Old 08-10-2020, 07:56 AM   #10
Rewards Points: 322
JoeyZ (08-10-2020)
Old 08-10-2020, 02:49 PM   #11
Rewards Points: 34
Hahaaa. I swear that for a few hours after I'd occasionally mumble "Yes! I got it!"
My wife would just shake her head.
I would not yield. I had to prevail.
