Mastercraft Door Frames Swelled And Broke - Windows and Doors - DIY Chatroom Home Improvement Forum
Like Tree6Likes
  • 2 Post By oh'mike
  • 2 Post By oh'mike
  • 2 Post By dwcopple
Old 09-16-2016, 10:30 AM   #1
Rewards Points: 111
Mastercraft door frames swelled and broke
Junk particle board with vinyl film wrap or something like that. Is is in a basement bathroom that had a water leak. Do they make vinyl or other water resistent casings I can fab my own frame out of and reinstall the doors? What other options do I have? Pressure treated sides and a standard pine top? Will the PT wood accept paint as easily as pine will?
dwcopple is offline   Reply With Quote
Old 09-16-2016, 10:55 AM   #2
Super Moderator
Gymschu's Avatar
Rewards Points: 6,624
Re: Mastercraft door frames swelled and broke
Most every lumber yard carries PVC trim these days. I'm sure you could make door casing from PVC that won't suck up moisture, warp, twist, and crack. I would avoid PT wood because it tends to crack as it dries out, although the newer versions of PT wood aren't quite as bad as the old stuff.
"In the heat of battle, my father wove a tapestry of obscenity........."
The Following User Says Thank You to Gymschu For This Useful Post:
dwcopple (09-16-2016)
Old 09-16-2016, 10:59 AM   #3
Rewards Points: 111
My concern is that the trim board would be hollow and where I need to router out for the hinges would expose a cavity or flex too much. Then I'd need to find some type of wood I could pound down from a cut end into the cavity as a backer. Do you think the PVC would be solid?
Old 09-16-2016, 11:56 AM   #4
JUSTA MEMBER
Rewards Points: 2,398
The Composite trim for decks is a solid material, that you can work quite well.
ED
de-nagorg is offline   Reply With Quote
Old 09-16-2016, 02:17 PM   #5
Rewards Points: 111
ED
wow, just got back from lumber yard and Menards. That board is super-pricey. Unreal.
Old 09-16-2016, 02:34 PM   #6
Retired Moderator
Rewards Points: 7,174
A solid wood (pine) jamb, properly painted will do what you want---no need for exotic treatment unless your basement goes under water regularly.
Gymschu and joecaption like this.
Old 09-16-2016, 03:03 PM   #7
Rewards Points: 111
Pretty sure that is what I am going to do. I have two doors like that (double access to room) and only one side on both is affected. I might just redo the one side of each door.
Old 09-16-2016, 03:10 PM   #8
Retired Moderator
That is what I would recommend--particle board is to fragile to be used as a jamb--
dwcopple and de-nagorg like this.
Old 09-16-2016, 03:11 PM   #9
Rewards Points: 111
kind of unreal how chintzy it is
The Following 2 Users Say Thank You to dwcopple For This Useful Post:
de-nagorg (09-16-2016), oh'mike (09-16-2016)
Old 09-16-2016, 04:33 PM   #10
JUSTA MEMBER
That is what I expect in the modern mass produced THROW AWAY world.
ED
Old 09-23-2016, 09:47 AM   #11
Rewards Points: 111
Pine worked out well. All primed and painted and matches good. Accepts trim nails a whole lot better too!
Gymschu and de-nagorg like this.
