How Much (new Cheap Hollow Masonite)door To Trim At Bottom For Carpet - Windows and Doors - DIY Chatroom Home Improvement Forum
Like Tree16Likes
  • 1 Post By de-nagorg
  • 3 Post By rjniles
  • 1 Post By mark sr
  • 4 Post By rjniles
  • 2 Post By sandmanX
  • 2 Post By de-nagorg
Old 08-23-2019, 09:16 AM   #1
Rewards Points: 6
how much (new cheap hollow masonite)door to trim at bottom for carpet
how much door to trim at bottom for carpet .
Replacing a Door and frame that opens to a carpeted room.
Cut the frame to fit the Rough Opening.
Now the Door Touches the floor Carpet .
I rather trim the door before installing it.
Carpet is the regular carpet that you find in HD or Lowes. The general kind.
would trinming Quarter inch work ? Thx
sandmanX is offline   Reply With Quote
Old 08-23-2019, 09:19 AM   #2
retired framer
Rewards Points: 4,616
Re: how much (new cheap hollow masonite)door to trim at bottom for carpet
Usually you want about 1" space under the door.
Do not use flat bottom gables with scissor trusses.
The Following 2 Users Say Thank You to Nealtw For This Useful Post:
sandmanX (09-24-2019), Technosoftinv (09-25-2019)
Old 08-23-2019, 09:22 AM   #3
retired painter
Rewards Points: 1,416
Be aware that the wood at the bottom of a hollow core door is only about 1.25" thick so you don't want to cut more than absolutely necessary .... or plan on replacing that wood.
mark sr is offline   Reply With Quote
The Following User Says Thank You to mark sr For This Useful Post:
Old 08-23-2019, 09:28 AM   #4
JUSTA MEMBER
Rewards Points: 1,084
The plug at the bottom of those doors can be CAREFULLY removed, then cut your door-skin down an inch or so, then slip the plug back in the door.
Not as hard as it sounds. Care and patience is your friend.
ED
ZZZZZ likes this.
de-nagorg is online now   Reply With Quote
Old 08-23-2019, 09:35 AM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 194
ED
I just mill a new filler from a 2x4.
Sent from my Moto E (4) Plus using Tapatalk
de-nagorg, mark sr and Nealtw like this.
My electrical answers are based on 2014 NEC, you may have local amendments.
The Following User Says Thank You to rjniles For This Useful Post:
Old 08-23-2019, 09:49 AM   #6
retired painter
Long ago I reused the bottom piece of wood but between removing it intact and removing the glue I found it's a lot easier to rip a replacement piece from a 2x on the table saw.
de-nagorg likes this.
Old 08-23-2019, 10:07 AM   #7
JUSTA MEMBER
A Spoke-shave, does quick work removing the glue.
ED
Old 08-23-2019, 10:10 AM   #8
A "Handy Husband"
rjniles's Avatar
Rewards Points: 194
ED
Owning that tool shows your age I bet most people under 50 could not pick one out of a line-up.
Dave Sal, de-nagorg, ZZZZZ and 1 others like this.
Old 08-23-2019, 11:01 AM   #9
JUSTA MEMBER
That's a bet, that I won't take.
And probably even less under 100, that knows what they were for.
ED
Nealtw likes this.
Old 08-23-2019, 12:46 PM   #10
Rewards Points: 6
Thanks a lot for replies .
de-nagorg and Nealtw like this.
Old 08-23-2019, 10:42 PM   #11
romeojk27's Avatar
Rewards Points: 14
ED
Okay Ed. Super curious here, can you post a couple of pics and what it was originally for?
romeojk27 is online now   Reply With Quote
Old 08-23-2019, 11:32 PM   #12
JUSTA MEMBER
Best that I can do is to post a link to an ornate one for sale on e-bay.
https://www.ebay.com/itm/J-Y-Simons-...cAAOSwoMddVx0m
A search there turns up 1,050 , for sale, do a see similar there and see them all.
They were designed to form the SPOKES for the old wooden wagon wheels, in the centuries of yore.
Some had curved blades to make the spokes round, others had flat blades to make the actual "tire" of the wheel flat, then an Iron tire was formed by a blacksmith for the heavier duty load hauling wagons.
There are sites on the internet that have much more information.
Search for wheelwright to read more.
ED
ZZZZZ and romeojk27 like this.
Old 09-24-2019, 09:25 AM   #13
Rewards Points: 6
Great answers thanks all. In my case I used a simple sol. I checked the old door height and setup and cut the bottom to that size . Being careful first time I cut less than actual did a dry Fit and then cut some more again . Its perfectly FLUSH and finely just grazing the top of the carpet nicely.
NOW THE BIG QUESTION : Once you get the solution how do you close the thread in a humanely possible way so further post on the thread are not posted. Thanks
SPS-1 and romeojk27 like this.
The Following User Says Thank You to sandmanX For This Useful Post:
de-nagorg (09-24-2019)
Old 09-24-2019, 09:40 AM   #14
JUSTA MEMBER
Ask any moderator, they "have the power".
ED
Old 09-24-2019, 10:20 PM   #15
Rewards Points: 492
So you got your closure. Leave it as is. 10 yrs from now, someone may think of a better mouse trap and may want to add it.
carpdad is offline   Reply With Quote
