Fixing Prehung Door - Windows and Doors - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 2 Post By chandler48
  • 1 Post By bcemail
Old 10-13-2018, 09:33 AM   #1
Rewards Points: 302
Fixing prehung door
I have a prehung door that has separated. I'm guessing the kids slammed it a few times and one side of the molding pulled away and it's not lined up with the jamb now. How do I put it back together? I was going to put a nail through the side with the latch plate thing into the jamb, but there is space between them and I was worried it wouldn't hold or would split the wood eventually. Should I nail the molding into the wall then reconnect the molding and the rest of the door? Hope this makes sense. I'm sure I'm butchering the terms! Thanks!
bcemail is offline   Reply With Quote
Old 10-13-2018, 09:42 AM   #2
retired framer
Rewards Points: 15,798
Re: Fixing prehung door
You want to cut the caulking between the trim and the wall and remove that and on the other side cut the caulk between the trim and door jam and remove that. Then you will be able to see what nails or screws are in there and what you need in the way of shims and nails or screws.
Old 10-13-2018, 09:43 AM   #3
Naildriver
chandler48's Avatar
Rewards Points: 3,752
It appears the door casing has separated from the trim molding. It happens when slipshod trim guys only nail the door unit by the trim molding. Push the door casing back into alignment to where it touches the trim molding and fasten the casing using either trim head screws or finish nails, then reattach the trim to the casing.
Mike Milam and mark sr like this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 10-13-2018, 11:21 AM   #4
Mike Milam's Avatar
Rewards Points: 324
Our house was built in 2003. When I had the trim off one side doing the bathroom tub replacement, I notice the door jams had no shims at all. Just nails thru the jamb (shot in with a nailer) into the framing. We are adults with no kids, so I'm not going to pull the trim on every door and shim the jambs. Just short cuts that are common now days.
Thank a police officer for being the one who runs 'TO' a report of shots fired, while everyone else runs 'AWAY'
Mike Milam is offline   Reply With Quote
Old 10-13-2018, 01:18 PM   #5
Rewards Points: 302
Thanks, I'll try that. I needed to anyway since it's pulling away and looks like crap!
Old 10-13-2018, 01:20 PM   #6
Rewards Points: 302
From what I can feel/see, there are no shims between the casing and the door jamb. If I nail or screw it, do I need to fill that gap with something? Or just use a few nails/screws and not try and tighten down to much?
Thanks!
Old 10-13-2018, 01:21 PM   #7
Rewards Points: 302
Yep, that sounds about right. As we've fixed up our house most of the work has been undoing shortcuts the builder and previous owner took!
Mike Milam likes this.
Old 10-13-2018, 03:23 PM   #8
Naildriver
chandler48's Avatar
To do it right, the trim molding needs to come off, the door and jamb installed using shims and then the trim reapplied.
Larry......
Old 10-13-2018, 06:52 PM   #9
Usually Confused
lenaitch's Avatar
Rewards Points: 2,106
Thanks!
As Chandler says, it needs to be attached with shims. If you try to nail or screw it 'just right' you will be frustrated and it will move over time, especially with kids slamming it. Shims allow the jamb to have solid blocking between the jamb and framing and be secured so it is straight all the way up. And don't just shim from one side - it could twist the jamb. Shims are tapered so you slide one in from each side at the same location make a flat spacing. There's probably YouTubes on it.
_________________________________________
Bydand
lenaitch is online now   Reply With Quote
Old 10-13-2018, 07:15 PM   #10
retired framer
Install new Patio prehung door but BIG gap between header and frame pl28 Building & Construction 3 02-19-2013 11:35 AM
Prehung interior door size help lornescot Windows and Doors 3 11-04-2012 02:27 PM
How To Size a Prehung Door? kc27 Windows and Doors 7 11-05-2011 01:52 PM
Need to replace front door, existing door non-standard size uncle Windows and Doors 1 07-25-2011 06:50 AM
Entry Door Size han Building & Construction 5 08-20-2009 07:54 AM
