Exterior Siding/entry Door - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 12-07-2015, 04:56 PM   #1
Rewards Points: 32
Exterior siding/entry door
I noticed the other day our side entry storm door was missing part of the siding at the bottom. What is missing and how do I replace?
Exterior siding/entry door-door.jpg
Lalamcd23 is offline   Reply With Quote
Old 12-08-2015, 10:23 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 7,872
Grab a piece of J-Channel to color match and replace if you want to keep that look.
Most go with a toe kick trim board in lieu of siding.
Old 12-08-2015, 10:46 AM   #3
Rewards Points: 18,256
Use utility trim not J molding. (also called under sill)
Reason being J sticks out to far from the wall and will funnel water behind the wall.
Old 12-08-2015, 11:04 AM   #4
Good idea Joe. Its not on the thickest part of the panel so it should fit fine.
Old 12-08-2015, 03:16 PM   #5
Rewards Points: 454
I would use j channel and undersill trim
scottktmrider is offline   Reply With Quote
Old 12-08-2015, 09:26 PM   #6
Rewards Points: 996
maybe its just me. but i don;t like siding in that area = just waiting to get damaged.
i would want something substantial there.
Fix'n it is offline   Reply With Quote
Old 12-09-2015, 12:08 PM   #7
CompleteW&D's Avatar
Rewards Points: 524
I agree, but the problem with removing the siding and putting a nice piece of cedar or PVC trim board under the door, is you would need to remove the j-channel running across the bottom and replacing the j-channel on each side of the door extending it down to the bottom.
CompleteW&D is offline   Reply With Quote
The Following User Says Thank You to CompleteW&D For This Useful Post:
Windows on Wash (12-09-2015)
Old 12-09-2015, 06:06 PM   #8
What's the distance from the threshold to the sheathing?
Anything beyond that is is going to act like a funnel to make any water run behind the threshold.
Looks like you already have issues.
Someones already tried wrapping the exposed wood with coil stock.
Using something like PVC lumber below the threshold would be best but if it sticks out beyond the threshold it's a waste of time and money.
Old 12-09-2015, 06:16 PM   #9
Rewards Points: 524
I dunno Joe.... maybe they wrapped the plate from a no paint or maintenance stand point.
But I completely agree that anything out past the threshold would be totally wrong. I still say, that replacing the j-channel on both sides of the door, along with cutting it out across the bottom of the door, just to put a piece of PVC trim board there, would be a LOT more work than a nice piece of dual or single undersill trim under that threshold and locking that siding back in place.
Just sayin....
Old 12-09-2015, 08:26 PM   #10
kwikfishron's Avatar
Rewards Points: 144
Just sayin....
I agree with all of this except that a "LOT more work" implies that it's difficult and/or time consuming when in reality it's not. 'In my eye' the difference is instead of it taking 15 min it takes 45.
Siding (especially vinyl) does not belong in that spot.
kwikfishron is online now   Reply With Quote
Old 12-10-2015, 02:01 PM   #11
Rewards Points: 524
Your right of course, but I was trying to look at it from a DIY point of view, not a pro who works with this stuff all the time.
Mahogany Door Jamb - What nails and where? Toronto Carpentry 25 07-26-2012 08:08 PM
Exterior Door won't seal Rhomadri Windows and Doors 8 04-28-2012 10:27 AM
Help with Swing out door into Breezeway/garage Brick wall! wad2k Building & Construction 3 04-25-2010 06:45 PM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 04:01 AM
Possible foundation, door gap problems Jemo Building & Construction 1 02-11-2007 09:43 AM
