Door Latch Screws - Stripped - Windows and Doors - DIY Chatroom Home Improvement Forum
Like Tree6Likes
  • 3 Post By Colbyt
  • 1 Post By DWooderson
  • 2 Post By DWooderson
Old 05-07-2019, 11:02 AM   #1
Rewards Points: 52
We have an exterior door that is in otherwise great shape, but the latch / backplate / faceplate screws are both stripped out. The wood is pretty gnarled up, and the latch moves around freely, and when the screws work their way out, they hit the jamb. It's an ugly scene.
Can I salvage this? The holes are in REALLY bad shape. They're basically just sawdust at this point, I think they've even expanded themselves into the latch hole.
What is the best practice here?
DWooderson is offline   Reply With Quote
Old 05-07-2019, 11:37 AM   #2
Rewards Points: 1,367
Re: Door Latch Screws - Stripped
Got pics?
huesmann is offline   Reply With Quote
Old 05-07-2019, 11:43 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 388
Use an oscillating saw, cut out a 12" piece of the jamb centered on the strike plate. Glue and screw a patch in place. Re-mortise the strike plate.
Sent from my Moto E (4) Plus using Tapatalk
My electrical answers are based on 2014 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 05-07-2019, 11:52 AM   #4
Rewards Points: 6,651
If it is just stripped holes and no visible cracks buy some wood glue and either a box of wooden matches or a small dowel rod. Use whichever and the glue to plug the holes then screw into the patch.
SPS-1, Dave Sal and Nealtw like this.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 05-08-2019, 07:09 AM   #5
Rewards Points: 1,948
You could check how far back the frame is and use a longer screw. With a countersink, you can also make the screw holes bit larger, but I think there are longer screws with heads that size.
carpdad is offline   Reply With Quote
Old 05-08-2019, 07:17 AM   #6
retired framer
Rewards Points: 14,154
If the door is in real bad shape buy a 3/8 plug cutter and make a plug to fit in a 3/8 hole with glue.
Do not use flat bottom gables with scissor trusses.
Old 05-09-2019, 04:45 PM   #7
Thing about filling the hole with toothpicks or such is that screws may not go in centered, which is bit important with door parts. Another is that jamb parts could start to split.
Old 05-09-2019, 07:10 PM   #8
Rewards Points: 494
Put 3.5Ē screws in there. It will go directly into the 2by4. Just donít screw it so tight that you move the jamb. Easy permanent repair and stronger then it ever was
BayouRunner is online now   Reply With Quote
Old 05-09-2019, 07:16 PM   #9
retired framer
He said the screws were hitting the jam, so I think it is the screws in the door that are the problem.
Old 05-11-2019, 12:33 PM   #10
Rewards Points: 52
It was hard to get a pic while the latch was still in place, and I only got time to remove the handleset today. Here is a video, the bottom screw hole is worse than I thought.
Too far gone to do the dowel rod repair?
https://i.imgur.com/iqjZVOQ.mp4
Old 05-11-2019, 12:45 PM   #11
retired framer
Old 05-11-2019, 01:08 PM   #12
Rewards Points: 52
It's funny you post that, I'm at my neighborhood hardware store, and they recommended J-B WELD WoodWeld Quick Setting Epoxy.
They don't have the product in that video.
I think I'm going to give this a shot, if it doesn't work, it might be time for a new door.
Nealtw likes this.
Old 05-16-2019, 08:41 AM   #13
Rewards Points: 52
Just to tie this off I did use the JB Weld WoodWeld Quick Setting Epoxy, and it seems to be working well.
THe lower screw area was the worst, the wood was pretty much gone. I filled it, let it set overnight, and then used a dremel to remove the excess.
For the top screw, I used the dowel rod technique.
I drilled holes for the screws, and then only snugged the screws, and the latch is holding tight and secure. Only time will tell how it will hold up to every day use, but so far, so good.
Thanks for all the suggestions!
Pics: https://imgur.com/a/1XNajHY
Colbyt and Nealtw like this.
The Following User Says Thank You to DWooderson For This Useful Post:
Nealtw (05-16-2019)
Screws / bolts securing brake rotors / drums WyrTwister Automotive Repairs 9 11-05-2015 09:59 AM
Fixing stripped screws in foam core steel door tigereye Windows and Doors 15 10-12-2015 05:46 AM
Stripped screws in chair Paul McMullin Carpentry 4 04-06-2010 02:41 PM
stripped screws econdave General DIY Discussions 8 07-07-2009 05:23 PM
Screws vs Nails in Interior framing project alexz Building & Construction 2 07-05-2006 05:58 AM
