Deadbolt And Knob Distance - Windows and Doors - DIY Chatroom Home Improvement Forum
Like Tree9Likes
Old 01-09-2020, 07:32 AM   #1
Rewards Points: 110
Deadbolt and knob distance
The distance from deadbolt to knob hole on this door is about 12". This does not match with anything I can see on the shelf. What needs to be done?
farmerjohn1324 is offline   Reply With Quote
Old 01-09-2020, 07:50 AM   #2
retired framer
Rewards Points: 5,604
Re: Deadbolt and knob distance
2 separate, a knob and a dead bolt . The knob can be like a bedroom knob with no lock. most sets work at what ever distance apart.
Do not use flat bottom gables with scissor trusses.
Old 01-09-2020, 07:52 AM   #3
Rewards Points: 110
Originally Posted by Nealtw View Post
2 separate, a knob and a dead bolt and a big thank you to the jerk that did that. The knob can be like a bedroom knob with no lock.
Wow. That's awful.
Nealtw likes this.
Old 01-09-2020, 07:57 AM   #4
Rewards Points: 110
Wouldn't it look very awkward to have a knob so low?
Old 01-09-2020, 07:57 AM   #5
retired framer
Originally Posted by farmerjohn1324 View Post
Wow. That's awful.
I just noticed the problem, who drilled the holes, they appear to close to the edge. Send it back.
Mike Milam likes this.
Old 01-09-2020, 07:58 AM   #6
Rewards Points: 110
Wow. That's awful.
So there's 2 problems?
Nealtw likes this.
Old 01-09-2020, 07:59 AM   #7
retired framer
Yes but they look wrong placed the other way too.
Old 01-09-2020, 08:16 AM   #8
hkstroud's Avatar
Rewards Points: 6,346
Remember that there is a center style of the other door when viewing from the exterior.
Harold,
The Left Handed Widget Maker
hkstroud is online now   Reply With Quote
Old 01-09-2020, 08:35 AM   #9
ZTMAN's Avatar
Rewards Points: 476
Did you purchase that door new?
I don't mind spending money, I mind wasting money.
ZTMAN is offline   Reply With Quote
Old 01-09-2020, 08:48 AM   #10
A "Handy Husband"
rjniles's Avatar
Rewards Points: 218
Center of lockset holes should be 2-3/8 or 2-3/4" from the edge.
Sent from my RCT6A03W13E using Tapatalk
SPS-1 likes this.
My electrical answers are based on 2014 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 01-09-2020, 08:59 AM   #11
Rewards Points: 2,080
I don't see a problem with the vertical spacing. The horizontal clearance mentioned above could be a problem. And the size of your cover plate may be a problem depending on that center piece between the doors.
huesmann is offline   Reply With Quote
Old 01-09-2020, 11:44 PM   #12
Rewards Points: 110
Most doors are 5.5-6" spacing. This is 13". The handle is practically at my knees.
Old 01-09-2020, 11:45 PM   #13
Rewards Points: 110
I know I need a dummy knob for the inside. But what about a dummy handle? Or dummy deadbolts? Certainly it can't just have 4 dummy knobs.
Old 01-10-2020, 09:04 AM   #14
So put the deadbolt at the bottom and the knob at the top? Or just fill the hole and cut your own.
Old 01-10-2020, 09:06 AM   #15
Rewards Points: 110
That's not the quality I would like from a $2000 door.
timkoupe, Mike Milam and Nealtw like this.
