Contemporary Window And Siding -- How To - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 02-18-2017, 03:26 PM   #1
Rewards Points: 6
Contemporary window and siding -- how to
I am trying to get this modern look on my facade that requires me to make the space in between my two vinyl windows look just like the frame on my vinyl windows (see below and attached pictures for examples).
How do I do that?
I'd appreciate your help.
Johannes is offline   Reply With Quote
Old 02-18-2017, 04:48 PM   #2
dd57chevy's Avatar
Rewards Points: 2,982
Re: Contemporary window and siding -- how to
Are you saying you want 15-18" of bronze cladding/metal between each "awning" window (last pic) ?
dd57chevy is online now   Reply With Quote
Old 02-18-2017, 06:35 PM   #3
Rewards Points: 6
Yes, that's what I'd like to know. Thanks for clarifying.
Old 02-18-2017, 10:27 PM   #4
Rewards Points: 6
To clarify further, everything except the space between the two awning windows will be stucco. The windows will have stucco fins. The space between the awning windows will be 4" wide to accommodate a support beam.
The 4" space between the windows, I'd like to be the bronze cladding. How to build it and how to keep water from getting in there?
Old 02-19-2017, 07:16 AM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 13,220
A stucco application should have a drip cap between it and the windows. That should be continuous if you are wanting to incorporate some trim between the windows.
The cladding could be installed up and under that drip cap, tie back to the edges of the window, and terminate on what should be a continuous sill pan of sorts. That would be ideal for drainage and water management.
Tags
contemporary , siding , window
Can I install window nail flange over siding? eholmes77 Windows and Doors 7 12-09-2015 05:33 PM
Window install RO? Didymus21 Windows and Doors 12 04-01-2013 08:28 AM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Adding a window - cutting through Aluminum Siding -how to repair siding to look good? DyerWolf Building & Construction 6 12-22-2008 04:02 PM
