Cedar Wood Porch Columns / Pvc Wrap Or Paint - Windows and Doors - DIY Chatroom Home Improvement Forum
Like Tree7Likes
Old 05-22-2020, 10:58 AM   #1
Rewards Points: 12
Cedar wood porch columns / pvc wrap or paint
When they built this home on Ď97 the builder used cheap nails (I tried to nail them in deeper) that keep rusting through. I could pvc wrap, but that gets pricey. How can I avoid the rust from seeping through otherwise? Any paint that Iíve tried in the past has failed.
4rpr is offline   Reply With Quote
Old 05-22-2020, 11:33 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 12,430
Re: Cedar wood porch columns / pvc wrap or paint
At least for those bottom ones, the water is coming from inside the wood and not outside.
Old 05-22-2020, 01:14 PM   #3
Rewards Points: 12
Thanks. Any ideas what I could do to 100% eliminate the rust from coming back?
Old 05-22-2020, 01:18 PM   #4
retired painter
Rewards Points: 1,338
If the moisture is coming from behind I don't know how effective it will be but I generally countersink the nails and then putty the resulting hole. That generally prevents the rust from coming back.
mark sr is offline   Reply With Quote
Old 05-22-2020, 01:43 PM   #5
Rewards Points: 12
I may have tried that and after some time the putty popped out.....my technique might have not been the best, what type of putty, how to make sure it doesnít pop out and then do I just paint over it ?
Old 05-22-2020, 01:44 PM   #6
The fact that the wood is right on the concrete isn't great. Really needs some sort of capillary break.
SPS-1 likes this.
Old 05-22-2020, 02:15 PM   #7
Rewards Points: 12
What would work out? Iím willing to try it.
Old 05-22-2020, 03:28 PM   #8
retired painter
I usually use window glazing to putty up nail holes on the exterior. You need to push the putty in with a twisting motion, then remove/smooth the excess. The paint should help to keep the putty in place.
4rpr likes this.
Old 05-22-2020, 09:04 PM   #9
Rewards Points: 12
Such as this? https://www.menards.com/main/paint/c...4428675667.htm
Help me understand the twisting motion when I cannot go deep into where the nail set is?
Old 05-23-2020, 04:45 AM   #10
retired painter
Dap33 will work fine. I take my thumb and push the putty into the nail hole rotating my thumb as I push it in.
Old 05-23-2020, 05:29 AM   #11
Rewards Points: 12
2 of the 3 problem areas donít have a nail hole to push it through. What would you suggest that I do in those areas?
Old 05-23-2020, 05:53 AM   #12
retired painter
Take a nail set to sink those nails. I should have mentioned that earlier - sorry.
Old 05-23-2020, 06:36 AM   #13
Rewards Points: 12
What if I tried a nail set and the nails still arenít budging?
Old 05-23-2020, 06:36 AM   #14
Rewards Points: 10,444
As previously mentioned, the wood on concrete is not great. If you search, you will find many threads in this forum on fixing rotted post bottoms. I would replace that bottom wrap with PVC. Yes, PVC is a bit expensive, but its only maybe 8" tall. A table saw would be nice for cutting those miters.
If you remove that bottom wrap, you get to see if you have a wooden post also sitting directly on concrete and headed towards eventual rot.
SPS-1 is offline   Reply With Quote
Old 05-23-2020, 06:41 AM   #15
Rewards Points: 12
Pvc on just the bottom wrap and not the post and top wrap would look awkward wouldnít it? Also, the rust is also occurring on the post as well, not just the bottom wrap.
