Best Sliding Glass Doors - Windows and Doors - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By SPS-1
Old 10-01-2019, 12:36 PM   #1
Rewards Points: 106
Best sliding glass doors
Obviously "best" has factors. Anyone rate a particular brand (Anderson, AC, Millgard, Marvin, etc) better or worse. Stay away from whom?
Looking to replace a 3 panel sliding glass door with minimal styles to maximize view. Have anderson (27 years old) and was considering just replacing with an exact match. Figured I'd ask for opinions.
thanks,
g
geenowalker is offline   Reply With Quote
Old 10-01-2019, 03:52 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 914
Re: Best sliding glass doors
I have a client who is replacing a large slider with an Andersen. We're waiting on it to come in, since it was special order. They aren't cheap ($2100) but seem to be good doors. It is a 400 series with painted metal on outside and wood inside.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 10-01-2019, 04:05 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 208
I have seen problems with vinyl or aluminum clad wood windows and doors. The seal leaks, water gets behind the cladding and never dries out. Wood then rots
I would go with either wood or solid vinyl. In either case go with composite jambs.
Sent from my Moto E (4) Plus using Tapatalk
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 10-01-2019, 04:36 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 7,864
What material do you want? There are good doors in all of the variants.
Old 10-01-2019, 06:51 PM   #5
Rewards Points: 106
Vinyl covered wood likely. Will liekly be a narrowline 200 or e series if andersen due to the think styles. Going in a beach commuity so the aluminum is out. Not dealing with wood maintenance.
Thanks everyone BTW.
Old 10-01-2019, 08:41 PM   #6
Rewards Points: 9,030
Andersen can do triple pane, Marvin can do double pane in a standard door.
SPS-1 is online now   Reply With Quote
Old 10-01-2019, 08:51 PM   #7
Originally Posted by geenowalker View Post
.... e series if andersen..... so the aluminum is out.
E series Andersen is aluminum clad wood.
Windows on Wash likes this.
Old 10-01-2019, 09:27 PM   #8
Rewards Points: 2,284
I'm currently replacing two Anderson 6' units that have been nothing but trouble.
The vinyl has pulled away in spots, and water has got to the wood. Screen never really worked worth a .....
Going budget this time with the Reliabilt (Jeld-Wen) 300 series doors, and so far, I'm happy with the one I've installed..
ktkelly is offline   Reply With Quote
Old 10-02-2019, 06:56 AM   #9
The Andersen doors are usually pretty darn good and if we were doing a comparison on the averages...much better than anything from Reliabilt or Jeld-Wen. Not trying to be argumentative here, but perhaps you got a lemon from andersen before, but they are overwhelmingly more proven than what you replaced them with.
