Awning Window Operator - Windows and Doors - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 1 Post By dd57chevy
  • 1 Post By ChuckTin
  • 2 Post By miamicuse
Old 07-10-2019, 06:35 PM   #1
Rewards Points: 3,088
Awning window operator
I have an awning window that will open but not close.
The handle will turn clockwise to open the window, but when I try to turn it counterclockwise to close the window, the handle comes loose and just spins.
If I push the handle in real hard and turn counterclockwise it will close a little bit. A closer examination of the handle doesn't appear anything is broken or cracked.
Any idea if I need a new handle, or a new operator?
miamicuse is offline   Reply With Quote
Old 07-10-2019, 07:01 PM   #2
retired framer
Rewards Points: 16,998
Re: Awning window operator
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Nealtw is offline   Reply With Quote
Old 07-10-2019, 09:10 PM   #3
dd57chevy's Avatar
Rewards Points: 3,048
Yes , your operator is toast .
You must have a Florida type window . I've never seen an awning type window with the operator on the side !
I believe you have 4 options :
1. Get a new one from the dealer (if you know the brand).
2. See if there is a specialty hardware business in your area . This would be a small business that usually sell locks , cabinet , door & window hardware .
3. Contact Blaine Window Hardware in Maryland
4. Steal one from your neighbor's window . This option could come with a collateral problems , though .
dd57chevy is offline   Reply With Quote
Old 07-10-2019, 09:17 PM   #4
retired framer
Home depot stocks a verity, every time I have tried they had what i needed. One had a screw in the wrong place so I had to drill one hole for a mounting screw.
figure 7-14
Old 07-10-2019, 09:35 PM   #5
dd57chevy's Avatar
You could be right .
I'm trying not to sound over-confident , because FL is a different world re: glass & windows . His may be common down there .
It's just that I've never seen a side mounted operator on an awning window . Or one with exposed mounting screws...
Nealtw likes this.
Old 07-11-2019, 07:53 AM   #6
Rewards Points: 126
Very common in Florida. I just had to operate on one. A clean up and a little aluminum lube goes along way.
dd57chevy likes this.
ChuckTin is offline   Reply With Quote
Old 07-12-2019, 04:07 PM   #7
It's quite common down here. I just went to Home Depot and looked and there are like half a dozen "similar looking" right hand operators and same number of left hand operator. Not sure the difference between them except there is a gear wheel on the back of the operator that seems to be different diameters? I guess I will need to take the operator off to do a match.
dd57chevy and Nealtw like this.
