Xps Vs Eps As A Thermal Break????? - Insulation - DIY Chatroom Home Improvement Forum
Old 03-25-2015, 05:12 PM   #1
Rewards Points: 145
xps vs eps as a thermal break?????
I guess true studies haven't been done on eps. What are your guys thoughts since eps is cheaper...
wantboost is offline   Reply With Quote
Old 03-27-2015, 09:25 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 846
Seems to work pretty good in coffee cups.
The Following User Says Thank You to Windows on Wash For This Useful Post:
concretemasonry (03-27-2015)
Old 03-27-2015, 12:16 PM   #3
Low Slope Roofing
Rewards Points: 114
EPS will absorb more moisture then XPS.
XPS has a slightly higher R-value.
Depends on what you are thermally breaking.
1985gt is offline   Reply With Quote
Old 03-27-2015, 12:18 PM   #4
Rewards Points: 846
Need to know application.
Old 03-27-2015, 03:40 PM   #5
concretemasonry's Avatar
Rewards Points: 2,716
The difference in water absorption can make a considerable difference in insulation since moisture can reduce the insulation (as it does for all materials) in the real world.
"R" value tests are short term tested on dry materials in pristine condition for advertising claims, so the moisture reduces the insulation more for EPS than XPS that will not absorb as much moisture in the real world. - Still not as bad as fiberglass that just holds moisture for almost forever.
Dick
concretemasonry is offline   Reply With Quote
Old 03-29-2015, 10:31 PM   #6
Rewards Points: 145
is it necessary to waterproof paint on the cinder blocks before installing the xps?
Old 03-30-2015, 07:00 AM   #7
Rewards Points: 846
Inside surface? No and actually not recommended.
Old 03-30-2015, 07:57 AM   #8
Low Slope Roofing
Rewards Points: 114
+1 the exterior needs to be waterproof.
Old 03-30-2015, 08:47 AM   #9
Rewards Points: 145
Yes interior and why not?
Old 03-30-2015, 11:57 AM   #10
Low Slope Roofing
Rewards Points: 114
Do you have moisture coming inside the walls currently?
Old 03-30-2015, 12:45 PM   #11
Rewards Points: 4,864
Water infiltration needs to be addressed on the outside with gutters, grading and downspout extensions.
stick\shift is offline   Reply With Quote
Old 03-30-2015, 01:47 PM   #12
Rewards Points: 846
It will form a vapor trap and there is nothing about that waterproofing paint that works, so why use it?
As stated directly above me, the water infiltration must be addressed from the exterior (ideally) or interior via drainage board and interior sump.
Old 03-30-2015, 03:16 PM   #13
Rewards Points: 145
Only at one spot. And slight amount of water. Due to a crack on the outside parging
Old 03-30-2015, 03:27 PM   #14
Low Slope Roofing
Rewards Points: 114
That should be fixed first before any interior finishes. The paint ect doesn't work, and if it does happen to work in this case will trap moisture in the foundation, not a great place for it to be.
The Following User Says Thank You to 1985gt For This Useful Post:
Windows on Wash (03-30-2015)
Old 03-30-2015, 03:28 PM   #15
Rewards Points: 145
Yes obv. I will fix that first. Ok i wont use the paint. Thx!
thermal break walls ? Fix'n it Insulation 16 05-20-2012 08:42 PM
Thermal Break mykquin Building & Construction 3 11-12-2011 08:13 PM
How to fix thermal break in cinder blocks tsg234 Carpentry 2 07-15-2011 12:32 PM
Thermal Barrier Windows vs Vinal Windows MeraleeCrowl Remodeling 6 11-05-2008 04:46 PM
Thermal Break For Tile fierysun Flooring 2 03-06-2008 06:22 PM
