XPS In Basement Around Pipes - Insulation - DIY Chatroom Home Improvement Forum
Old 01-02-2019, 06:48 PM   #1
Rewards Points: 126
XPS in basement around pipes
I am planning to finish my poured concrete basement with 2" XPS over the concrete, with a 2x4 framed wall in front with fiberglass insulation and drywall.
I have some plumbing attached to one wall, and although I know a continuous insulation layer would be ideal, I would really like to avoid moving them. Can I cut pieces to fit around the pipes, or would I end up with condensation issues? If I cut around, should I seal against the pipes with expanding foam? Or tape over a plastic vabor barrier?
XPS in basement around pipes-basement1.jpg   XPS in basement around pipes-basement2.png
garrett1812 is offline   Reply With Quote
Old 01-02-2019, 09:41 PM   #2
APA
Rewards Points: 254
Re: XPS in basement around pipes
I am not a basement guy, but there is NO way I would move those drain lines...
APA is offline   Reply With Quote
Old 01-03-2019, 09:04 PM   #3
When I did my basement last year, most of my research leaned towards not using fiberglass batts over xps. A faced fiberglass creates a situation where moisture can get trapped between 2 vapor barriers. I did piece xps around drain lines and spray foam the remaining gaps. Also, tape the seams to prevent moisture getting through the seams of the xps and condensing on the concrete.
Sent from my SM-G900V using Tapatalk
cmwhitmoyer is offline   Reply With Quote
Old 01-03-2019, 10:11 PM   #4
Rewards Points: 126
I plan to tape or caulk the XPS seams, and use unfaced fiberglass, as I donít want to vapor barrier here. For my climate 2Ē XPS will be a sufficient vapor barrier. Good to hear you just sealed around drain lines. I assume no issues?
Insulating basement walls - dealing with waste pipes mjonis Insulation 6 12-27-2017 09:53 AM
Basement floor pipes Kevinstina625 Building & Construction 1 12-20-2015 02:52 PM
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 08:40 AM
What are these pipes in my basement Poolhouse4320 Plumbing 5 06-04-2015 08:24 PM
running pipes in outside wall (Basement) BlueBSH Plumbing 1 10-18-2010 11:30 AM
