Xps - Insulation - DIY Chatroom Home Improvement Forum
Old 12-21-2013, 05:47 PM   #1
Xps
What do you pro's use to cut XPS 1" foam board? I have used a utility knife in the past but unless its brand new I feel as though I am ripping it apart more than I am cutting. Was just curious if there was a certain saw, blade or combo that works well. TIA
lk00331 is offline   Reply With Quote
Old 12-21-2013, 07:48 PM   #2
bbo
utility knife makes the least mess in my limited experience. score and snap.
bbo is offline   Reply With Quote
Old 12-21-2013, 07:58 PM   #3
Rewards Points: 1,864
http://www.sears.com/festool-493656-...2&blockType=G2
Old 12-29-2013, 09:49 AM   #4
Thanks guys! Went with a utility knife and it worked.....just changed the blades out quite often
