Winter Frost And Dryloc - Insulation - DIY Chatroom Home Improvement Forum
Old 05-13-2012, 11:33 PM   #1
Winter frost and dryloc
Thanks for this discussion. It has helped me decide to NOT vent my cabin crawlspace which a contractor suggested. One thing I don't understand: When I asked about running plastic up the inner concrete wall from the dirt floor and applying a waterproof barriet such as Dry-Lock, he said to do neither as the winter frost and ice would break through both. He suggested just leaving the walls bare and having passive vents reduce humidity. Any thoughts?
lofushar is offline   Reply With Quote
Old 05-14-2012, 12:08 AM   #2
Registered User
Rewards Points: 526
Welcome to the forum!
Where are you located?
Gary
