Will Polyurethane Spray Foam Melt XPS? - Insulation - DIY Chatroom Home Improvement Forum
Old 08-17-2015, 01:47 PM   #1
Rewards Points: 186
Will Polyurethane Spray foam melt XPS?
We put up 2" think XPS (expanded Polystyrene) foam around the basement walls and we're about to spray polyurethane closed cell foam Tigerfoam or similar, and just wanted to confirm if I oversprayed it wouldn't melt the XPS? Thanks
Ocelaris is offline   Reply With Quote
Old 08-17-2015, 06:22 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 826
They should work fine together.
Is this a bulk application spray foam or just spray foam for air sealing purposes?
Old 08-17-2015, 07:17 PM   #3
Rewards Points: 186
It will be bulk in the sense that I'm covering the rim joists, but air sealing is my main concern. Since we have about 200 feet of linear sill plate and a 200 board foot wouldn't be enough to cover adequately, I'll probably go around a second time and hit under the bathroom's heated floor etc...
Old 08-18-2015, 05:08 AM   #4
Rewards Points: 826
Should be fine. Do a small test spot first and be sure you don't over apply the CC SPF in two thick a layer. The heat can pose a problem.
https://www.google.com/?gws_rd=ssl#q...ith+spray+foam
Old 08-18-2015, 07:02 AM   #5
Rewards Points: 186
Thanks, here are some pictures of the progress. I'll try and update when we get the foam done. I had heard about the 2nd layer causing issues... I just am probably a bit short with 200 board feet given the irregularities of product, i.e. if I am out of foam on the last 10 feet it'd be a real pain to do it by hand with the cans. I'd do foam blocks with the extra XPS, but we're short on time as it stands...
The Following User Says Thank You to Ocelaris For This Useful Post:
Windows on Wash (08-18-2015)
Spray foam Question b lowell Insulation 4 01-30-2013 02:34 PM
Spray foam in attic diystephen HVAC 6 12-29-2012 01:07 PM
Anti-Microbial DIY Polyurethane Spray Foam Kit Recommendations... WGFA Insulation 9 12-03-2012 09:29 AM
Spray Foam in Walls & Moisture Question leeave96 Insulation 4 11-12-2012 11:43 AM
DIY spray foam ACR_SCOUT Insulation 12 12-30-2011 06:57 AM
