What Type Of Spray Foam And Adhesive Is Best To Use With XPS Insulation? - Insulation - DIY Chatroom Home Improvement Forum
Old 11-01-2014, 01:52 PM   #1
Rewards Points: 397
What type of spray foam and adhesive is best to use with XPS insulation?
I'm going to put XPS insulation in the stud bays up against the concrete block wall of my basement. We had water problems on that wall, but I think I've corrected them from the outside. But there's the possibility that the concrete block could get moist in the future.
Considering that, what is the best adhesive to use for the foam board, up against the concrete. Are some more water resistant than others?
And what type of spray foam do you recommend for filling the gaps/edges around the XPS foam boards? Should I use minimal expanding spray foam or the stuff that expands more?
Thanks much for your help!
Studly is offline   Reply With Quote
Old 11-01-2014, 01:56 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,242
They all work about the same.
If the wall has water in it, it will push the adhesive, foam, etc. off the wall.
Closed cell, window and door foam works well for sealing up gaps.
Tack in some strips inside the stud wall to hold the foam down if you want or if the walls have a gap between the stud and concrete, wedge some shims in there to pinch the foam to the wall.
How to remove vinyl adhesive and foam insulation? dodan Plumbing 4 02-05-2012 04:34 PM
Foam Insulation Questions - Please help kuj0317 Insulation 3 01-27-2012 07:31 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Adhesive for R MATT foam board captainrichhill Building & Construction 2 05-24-2010 05:40 AM
What adhesive to use for EPS rigid foam insulation creamaster Building & Construction 1 04-01-2010 07:00 PM
