What Is The Proper Way To Insulate An Attic Furnace? - Insulation - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Nealtw
Old 11-09-2017, 03:12 PM   #1
Rewards Points: 392
Question
What is the proper way to insulate an attic furnace?
What is the proper way to insulate an attic furnace, when the rest of the attic is unfinished?
enochian is offline   Reply With Quote
Old 11-09-2017, 04:36 PM   #2
Rewards Points: 1,918
Re: What is the proper way to insulate an attic furnace?
#1, We have no idea where you are because there's no location in your profile.
Most often just the ducts get insulated.
Old 11-09-2017, 04:38 PM   #3
Rewards Points: 392
Pennsylvania
Old 11-09-2017, 04:41 PM   #4
retired framer
Rewards Points: 976
You want to protect the roof from heat or you could cause ice dams.
Insulated ducts like Joe said and very good venting to move any lost heat away.
joecaption likes this.
Old 11-10-2017, 12:44 AM   #5
Rewards Points: 326
Do you have enough room in that attic to build a room for the furnace, insulated and air sealed to keep the heat out of the cold attic.
Basically, if you can't contain the heat given off by that unit then you have to waste it to the outside to prevent snow melt and those resulting ice dams.
Bud
Bud9051 is offline   Reply With Quote
Old 11-10-2017, 07:26 AM   #6
Rewards Points: 392
The ducts are ductboard and are insulated as well.
Old 11-10-2017, 07:29 AM   #7
Rewards Points: 392
I don't know if the truss system can handle the weight of drywall etc.
Plenty of space though.
Can you just use 2x3's and polyiso? Is polyiso allowed near an attic furnace without a thermal barrier?
Old 11-10-2017, 07:42 AM   #8
Rewards Points: 326
Hard to build anything up ther with trusses and the furnace already there. An air barrier needs to be sealed and rigid and plastic does neither. Only thing that comes to mind is foil faced foam all taped up, if codes would allow it. They do sell duct board in 4x? sheets (I found 4'x10' near me) and it has a reasonable r-value. Plus it is basically rigid fiberglass insulation and not very heavy.
Bud
Old 11-10-2017, 07:49 PM   #9
user_12345a's Avatar
Rewards Points: 128
I don't see a point of insulating the area where there's a furnace when the rest of the system, the ducts, have direct exposure.
to really save energy $$$ u you have to insulate the roof deck, but that's a lot of money up front.
otherwise just make sure everything is sealed up well and make sure the insulation on your ducts is a reasonable r-value, like r8.
it's not a smart place to put ducts or equipment, but once it's done, make the best of it.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is offline   Reply With Quote
gap around attic entry of furnace flue Dave Sal Insulation 15 11-17-2013 12:09 PM
Insulating your attic Bob Mariani How To Guides 5 07-07-2013 08:49 PM
Insulate Attic. No soffit vents. Roof vents yes. jefsboys Remodeling 14 06-29-2012 11:40 AM
Quote for new furnace. Reasonable? dengle HVAC 16 03-04-2012 07:01 AM
Proper Attic Insulation reikiray Roofing/Siding 5 08-04-2007 10:59 AM
