What Is Belly Board? - Insulation - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 2 Post By Nealtw
  • 1 Post By mark sr
  • 1 Post By form8829
Old 04-28-2019, 09:24 AM   #1
Rewards Points: 792
What is belly board?
Below is the note from the inspector:
Make sure underside of double wide home is properly insulated and sealed with belly board.
What materials can use from Lowes to do this?
form8829 is offline   Reply With Quote
Old 04-28-2019, 09:40 AM   #2
JUSTA MEMBER
Rewards Points: 98
Re: What is belly board?
Any sheet goods. I.E. plywood, particle board, O S B, etc.
Mobile home makers use the cheapest thing possible, and it often falls out.
ED
de-nagorg is online now   Reply With Quote
Old 04-28-2019, 11:18 AM   #3
retired framer
Rewards Points: 362
I would ask the inspector to clarify, because I don't like doing things twice.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Old 04-28-2019, 11:32 AM   #4
retired painter
Rewards Points: 76
I don't know that I've ever seen any type of board being used by the manufacture under a mobile home. Most use a 'plastic' referred to as belly wrap. When I've had to repair the insulation under a MH I've used tar paper, foam board or whatever I thought would work best. The main thing is to keep the insulation in place as it insulates the pipes and duct work along with the floor.
mark sr is offline   Reply With Quote
Old 04-28-2019, 11:36 AM   #5
retired framer
Rewards Points: 362
They use fabric so it can breath.
figure 7-14
Old 04-28-2019, 12:53 PM   #6
JUSTA MEMBER
Rewards Points: 98
These must be newer MH, all the ones that I am familiar with, from the 60s-80s, had a fiber board sheet, then a plastic like the old visqueen, then the insulation ( fiberglass), all below the plumbing, then the particle board floor, with a rolled linoleum flooring.
It was easy for feral cats to rip into the bottom sheet of fiber board, and nest in there, if the owner did not skirt them properly.
Also if no skirting, they often froze up and burst Copper plumbing.
ED
Old 04-28-2019, 01:12 PM   #7
retired framer
Rewards Points: 362
ED
Might depend on where you live.
de-nagorg and mark sr like this.
figure 7-14
Old 04-29-2019, 05:15 AM   #8
retired painter
Rewards Points: 76
Mobile homes are built for the region they are sold in; near the ocean they are built to withstand more wind and I assume those for up north are built different to withstand the cold. The MHs here in the southeast always made me wonder how anyone could live in one in the far north. If I remember correctly on the fuse/breaker box there is a sticker stating what region that particular MH was built for.
de-nagorg likes this.
Old 04-29-2019, 08:54 AM   #9
Rewards Points: 792
thanks everyone
Emerson 47D01U-843 Defrost board algorithms / operation azchris HVAC 23 12-26-2017 02:49 PM
Ruud Gas Furnace Board Upgrade Question rlgdtime HVAC 9 12-16-2017 04:57 PM
Lennox Furnace with 63K8901 circuit board behaving strangely tgice HVAC 4 06-21-2013 01:03 PM
Fascia board install - unlevel rafter tails giperbolic Roofing/Siding 3 01-17-2012 11:46 PM
shower rebuild - need help with backer board & green board johndoe12345 Tiling, ceramics, marble 2 11-27-2011 01:16 PM
