Wanting To Insulate My Floors - Insulation - DIY Chatroom Home Improvement Forum
Old 12-16-2014, 09:39 PM   #1
Rewards Points: 750
Wanting to insulate my floors
Having heat loss through my floor. Unsure what the best way to go about adding insulation would be.
My current plan is to get spray foam insulation. The house is a pier & beam foundation of 2' wide spacing on 2X6.
I looked up costs & this looks like it will run me around a thousand to do the entire 400sqft footprint.
Is there any cheaper option one would suggest? I am unsure how else I could insulate the floors. Thanks.
Hick is offline   Reply With Quote
Old 12-16-2014, 10:01 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,932
2' Spacing? With 2x6? I'm more inclined to think it's 16" OC.
I personally would use fiberglass batts. That is what I used. I got the kind that is fully encased in plastic. Paper faced could get messy if it gets wet.
It comes in rolls. Measure the length of your joist bay...cut the insulation to length....drag under the house and put up into the bay.
You can use a stapler to hold them in place...or get a box of wires....they make these think stiff wires that fit perfect between two floor joists that are 16" OC. It's real fast.
Makes a big difference on keeping floors warm.
Mind you, it's not exactly fun....and the beer cost can be high.....you know, hang a couple of rows....grab a beer and admire your work....hang a couple more....grab another beer and pat yourself on the back....hang a couple more....convince yourself that the money your saving in heating will pay for more beer.
ddawg16 is online now   Reply With Quote
Old 12-16-2014, 11:28 PM   #3
Rewards Points: 750
It might be 16" OC. I would have to get up under there & look but fairly sure its 2' OC.
I am okay with the beer cost being high. I considered fiberglass batts, my biggest concern with that however is keeping bugs from getting up into it.
I think I found a solution that might work & comes in around 250 bucks, though the R value will only be around 8.
Old 12-17-2014, 08:09 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 826
Heat loss through the floor will be minimal.
Batt insulation should work fine and if you want super high performance, cover it with some rigid foam.
Old 12-17-2014, 08:26 AM   #5
ZZZZZ's Avatar
Rewards Points: 322
I insulated my floor over an unconditioned crawl space last year. I heat the house almost exclusively with a wood stove and I'm sure a lot of air was leaking up through the floor as the stove burned.
I didn't do a scientific study, but overall the comfort level is much higher and I'm burning a lot less wood.
Used R-19 fiberglass batts and metal rod hangers. Took me about 4 days for a 24 x 40 floor. I think I could have done it in 2 days, but I was getting claustrophobic due to the low ceiling in the crawlspace. I just needed to get out of there and take breaks every few hours.
ZZZZZ is online now   Reply With Quote
Old 12-17-2014, 11:43 AM   #6
Low Slope Roofing
Rewards Points: 114
Any insulation will be prone to bug/insect and rodent damage. Birds love spray foam. They need to keep warm too!
1985gt is offline   Reply With Quote
Old 12-17-2014, 11:02 PM   #7
Registered User
Rewards Points: 526
FB or FG batt insulation with lath holding up some housewrap could work- or both; http://www.buildingscience.com/docum...n-crawlspaces/. On your earlier foil faced foamboard for walls, either direction; pp. 26?; http://www.buildingscience.com/docum...endations/view
Gary
Please evaluate these floors Rosalini32 Flooring 13 11-08-2019 05:24 PM
Cracks in grout of recently tiled bathroom floors kbklarry Tiling, ceramics, marble 78 09-15-2014 07:08 PM
Insulate duct work svaic00 Insulation 2 07-21-2013 10:19 PM
Help! Shellac color too dark on floors atreyu312 Flooring 3 08-15-2010 06:28 PM
how to insulate floors above an unheated basement? mfrenkel Building & Construction 4 07-23-2010 02:59 PM
