Vapour Barrier In Bathroom - Insulation - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Bud9051
Old 03-17-2019, 12:07 PM   #1
Rewards Points: 2
Vapour barrier in bathroom
Hi,
I am replacing the old bathroom ceiling fan and had to remove the whole housing unit.
I was able to get the old one out but now I realized the vapour barrier is not intact. Me yanking out the fan didn’t help, but to me it seemed this wasn’t properly installed to begin with.
I also noticed the insulation to be moldy.
- can I live with this or is it advisable to remove the entire drywall ceiling and re-do this?
- if I only line the hole for the new fan with 6mil sheathing how do I manage to efficiently plug the hole for the duct and electrical? Do I need to cut around the area to put the plastic cover back in?
Hepeto is offline   Reply With Quote
Old 03-17-2019, 12:20 PM   #2
retired framer
Rewards Points: 62
Re: Vapour barrier in bathroom
Do you have access to the attic?
Do not use flat bottom gables with scissor trusses.
Old 03-17-2019, 12:37 PM   #3
Rewards Points: 2
Unfortunately not, there seems to be limited space in the ceiling - Less than 10 inches clearance
Not entirely sure if it is really moldy or just dust and grime accumulated over the years. It’s very dry in there
Old 03-17-2019, 01:15 PM   #4
retired framer
Rewards Points: 62
Not entirely sure if it is really moldy or just dust and grime accumulated over the years. It€™s very dry in there
When house air gets past insulation it will drop off moisture and the dust in the insulation. even if there is a little mold if dry, you have already spread the spores. When I have changed one like that I found the poly had just been cut around the box. So I just made sure all the holes in the box were sealed with fire rated caulk from the inside, then I put aluminum tape from the inside of the box down onto the ceiling. just enough for the grill to hide the tape.
Old 03-18-2019, 10:41 AM   #5
Rewards Points: 2
Would you suggest to take it all out?
I was thinking to cut around the area to see what’s behinf it and to give me more access to line it with poly
Old 03-18-2019, 01:59 PM   #6
retired framer
Rewards Points: 62
I wouldn't, I think no matter how much you destroy trying to seal it there will always be something that just hard to seal. I would seal all the holes that would let air out of the box from the inside and then try to stop air that might just get by it at the ceiling.
Old 03-18-2019, 05:26 PM   #7
Rewards Points: 6,770
Although bathrooms have a lot of moisture, assuming a shower, by adding a delayed off switch to keep the fan running for 20 minutes after being turned off that moisture risk drops significantly.
The other issue which they have learned is more important than a vapor barrier is air sealing. What you describe sounds more like an air leak issue than a vapor barrier issue. Here's a good link.
Bud
Nealtw likes this.
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is offline   Reply With Quote
1946 home with no bathroom - vapor barrier question Jaybone104 Kitchen & Bath Remodeling 7 11-04-2014 08:25 PM
double vapour barrier in Canadian basement wall Buzzman Insulation 4 07-30-2014 02:09 PM
Basement Vapour barrier issue. EasternCanadian Insulation 15 01-26-2013 11:33 AM
Old paper-backed insulation = Vapour Barrier? billyh Building & Construction 3 03-15-2011 09:38 PM
Drylock, Typar and Vapour barrier? fubar79 Building & Construction 5 11-06-2009 12:35 PM
