Vapour Barrier In Balloon Framing - Insulation - DIY Chatroom Home Improvement Forum
Old 10-13-2014, 10:24 AM   #1
Rewards Points: 2
Vapour barrier in balloon framing
I have an old un-insulated balloon framed house built in the 1920's in southern ontario. the exterior is wood siding under vinyl siding with the old black paper house wrap sheated with barn boards. I tore the lathe and plaster off to insulate the exterior walls, strapped it out to 2x6 and installed roxul all around. Now I'm at the vapour barrier stage and am wondering since the studs run floor to the roof, when I attach the vapour barrier how should I attach it at the ceiling where the next floor is to minimize air transfer? Should I attach it to the outside wall or should I attach it to the floor joists and the upstairs floor?
matt1989 is offline   Reply With Quote
Old 10-13-2014, 11:06 AM   #2
Rewards Points: 1,870
Pull it back out, you missed an important step.
You needed to add fire blocking before insulation.
Fire blocking is nothing more then adding solid wood at the top and bottom of the walls and using high heat expanding foam to seal any cracks or where wires or plumbing was run.
Old 10-13-2014, 04:15 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 878
Gotta block it out, air seal, and then vapor barrier it.
Platform AND Balloon Style Framing In One House??? NTL1991 Building & Construction 2 06-01-2012 12:22 PM
Vapour Barrier vs Vapour Retarder in Basement Floor. PTO Flooring 0 07-13-2011 11:41 PM
Basement vapour barrier eickholdt Building & Construction 15 10-29-2010 03:47 PM
vapour barrier HELP!!!!! 06GT General DIY Discussions 8 02-23-2010 08:01 AM
basement insulation and vapour barrier coolnes Remodeling 11 02-01-2009 08:56 AM
