Vapor Barrier For Pole Barn Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 02-12-2014, 10:31 AM   #1
Rewards Points: 20
Vapor barrier for pole barn insulation
I live in ohio and have a metal pole barn. I was wondering should I put a vapor barrier over the stringers and against the metal. Then I'm going to use cellulose to spray for insulation then put ply wood up. Or should I put the cellulose insulation in the vapor barrier then the ply wood walls. Not sure what to do I have a wood stove in the barn, it's not going to be warm in there all the time maybe twice a week when I want to go out there and work. Thanks in advance for your help
golfthis1123 is offline   Reply With Quote
Old 02-13-2014, 11:19 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 848
Not a fan of cellulose in sealed attic/hot roof designs.
How large is the space/roof?
Old 02-14-2014, 10:11 AM   #3
Rewards Points: 20
The barn is 30x40 I am just trying to figure out ideas on how to insulate the barn semi inexpensive without having to use the spray foam insulation. I got a quote for the spray foam and to do the whole barn was going to be around $5-6,000.
Old 02-14-2014, 03:44 PM   #4
Registered User
Rewards Points: 526
http://energycode.pnl.gov/EnergyCode...jsp?state=Ohio
http://www.buildingscience.com/docum...commendations/
http://www.designandbuildwithmetal.c...h_7_13_09.aspx
http://www.mbma.com/pdf/2009Condensa...eet_112509.pdf
https://docs.google.com/viewer?a=v&q...BVNosB7b20gXwg
Problem is making sure no air gets to the metal roofing or supporting frame for conduction. Notice "thermal breaks" mentioned and "air-tight"......
Gary
Insulating your attic Bob Mariani How To Guides 5 07-07-2013 08:49 PM
400 amp service pole barn and home later walt1955 Electrical 2 06-29-2012 09:08 AM
Basement Ext Wall - Will Rigid Insulation allow my wall to dry inward? COLORADOMTNMAN Insulation 10 01-15-2012 10:09 PM
another barn wiring question wendell2 Electrical 10 05-29-2011 08:04 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
