Vapor Barrier On Out Building - Insulation - DIY Chatroom Home Improvement Forum
Old 04-30-2020, 01:08 PM   #1
Rewards Points: 986
Vapor barrier on out building
My cousin is working on turning an old chicken coop into a functional space for working out/ playing music. Probably close to 100yr old building built with hollow clay block, concrete floor, wood framed roof with tin covering shake shingles. Not sure how he plans to heat/ cool the space, discussed mini split, but no solid decision made yet.
I plan on helping him frame the interior walls, so he can run electrical and then install some sort of wall covering soon. He's thinking shiplap or something, doesn't think any drywall. Out in the country and no inspections or permits, but trying to do mostly correctly.
The question is, what's the best way to vapor barrier this so he can hang bat insulation in the 2x4 wall cavities?
I suggested, 1/2" foam taped seems and spray foam the joints in hard to manage areas as I've seen that being method for basements. What about xx mil plastic sheets? Either stretched across back of 2x4 framing and stapled or attached to roof framing and draped to the floor, so the batting can't contact the block?
I'm not sure if the vapor barrier is essential as we're in South Central Kansas and heating/ cooling seasons are about equal here. Main goal is to protect the batting. But looking for input. We don't want to have to go back later.
Master Brian is offline   Reply With Quote
Old 04-30-2020, 01:09 PM   #2
Rewards Points: 986
Duplicate, not sure how to delete. Please don't respond to this one.
Old 04-30-2020, 01:30 PM   #3
Rewards Points: 124
Re: Vapor barrier on out building
Here is the other thread:
https://www.diychatroom.com/f103/vap...ilding-686463/
Bud
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is offline   Reply With Quote
Old 04-30-2020, 02:06 PM   #4
Rewards Points: 248
There is a reason chicken houses were built of clay tile block with shake shingles and there is a reason it still stands and will be standing when you'll see buildings much newer have fallen to the dirt. I'd leave -er alone and workout early A M in summer and late P M in winter.
