Vapor Barrier Is Not A Air Barrier Make! It Is A Vapor Retarder - Insulation - DIY Chatroom Home Improvement Forum
Old 04-16-2014, 09:35 AM   #1
Rewards Points: 626
Vapor barrier is not a air barrier make! It is a vapor retarder
After explaining till I was blue in the face with a home owner that was up set with me for not using faced batts. because then the home is not air sealed. I finally had to take a piece of sheetrock place it over the exhaust of my shop vac and ask HO how much air is getting through the sheetrock???? um none was there reply. Exactly! Kraft facing poly are vapor retarders not barriers they are not interchangeable meanings a vapor barrier is about 6 mill thick and up a vapor retarder is about less than 4 mil thick. and lets moisture vapor to escape the house one way and not enter the other way. house wrap is a retarder as is plywood. In fact the HO had the county building inspector come over to give me a talking to. for non using paper faced insulation. the inspector told them the house has tyvex wrap 5/8th plywood sheathing it has a vapor retarder to let the water vapor out.
Nailbags is offline   Reply With Quote
Old 04-16-2014, 09:11 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 934
Sick em!!!
Old 04-19-2014, 02:29 PM   #3
Registered User
Rewards Points: 526
Yes, vapor barrier/air barriers can be confusing. Code requires a vapor barrier directly under the drywall- depends on the class. Asphalt coated paper is a Class 2 VAPOR barrier, drywall is an AIR barrier- two different design solutions. The faced batts retard moisture- drywall lets moisture diffuse through it but stops air. http://publicecodes.cyberregs.com/ic...9_6_par004.htm
None of the vapor barriers/retarders let moisture through one way only- if they are permeable (retarders)- it is both ways, including housewraps. Paper-faced insulation (vapor permeable) is the code-required vapor retarder, house wrap is the required Water Resistive Barrier (vapor permeable) on the outside of cavity, and plywood/OSB is the required structural sheathing (vapor permeable)--- unless it is Advantech sheathing. http://publicecodes.cyberregs.com/ic...9_6_par005.htm
In a heating climate, codes require the vapor barrier/retarder under the drywall to stop/slow outward bound moisture. Homeowner is correct. Is this in Oregon?
http://publicecodes.cyberregs.com/ic...9_6_par006.htm
Gary
Old 04-21-2014, 07:23 AM   #4
Rewards Points: 626
It is in washington state and the county I work and live in does not require any form of vapor retarder between the sheetrock and insulation because they found it is a habitat for mold growth. no poly is required no kraft face no nothing. they feel two coats of PVA primer is sufficiant.
Old 04-21-2014, 07:02 PM   #5
Registered User
Rewards Points: 526
Yes, specific vapor retarding paints are acceptable in WA, though I have seen workers apply them similar to regular primers- just coat the wall. Most are very specific about thickness/coverage of application, ranging from 6-12+mil and 120-400 sq.ft. per gallon. Hence the clause; "Materials must be applied in accordance with the manufacturer’s instructions to achieve specified permeance ratings." from our WA guide; http://www.google.com/url?sa=t&rct=j...,d.aWc&cad=rja
It is code accepted, just not widely known; http://www.ecohome.net/guide/painting-vapour-barrier
Shame on the inspector for not explaining it correctly to the HO.
Gary
PS. a good local study for WA (PVA primer included); https://docs.google.com/viewer?a=v&q...NmmYf-psHZnLA;
Vapor barrier or not? BigJimmy Building & Construction 3 04-07-2013 11:30 PM
Make waterproof barrier between plywood wall and concrete foundation. gbradley Building & Construction 1 10-24-2010 01:48 PM
insulate & vapor barrier around electrical box acerunner Electrical 7 04-26-2010 09:32 PM
Reattach gutters--caulk leak barrier? soubriquet Roofing/Siding 6 04-16-2010 08:38 PM
Should I use a vapor barrier on each side? Hossenfeffer Building & Construction 3 04-09-2010 10:12 PM
