Vapor Barrier In Garage? - Insulation - DIY Chatroom Home Improvement Forum
Like Tree7Likes
  • 1 Post By Fix'n it
  • 2 Post By bob22
  • 2 Post By u2slow
Old 09-15-2020, 09:17 AM   #1
donste2010's Avatar
Rewards Points: 160
Question
Vapor barrier in garage?
Hi all,
I'm not a newbie but I haven't been on here in years, how are you all doing? Hey so, my wife and I have moved to Charlotte, NC area, and they only drywalled the garage walls so far, like 1/2 way to the garage door, so I am doing the rest. Question is, do I put vapor barrier up? If so which side, facing the inside or the outside of the cavities? I am just looking to keep the garage warm in the winter months so I can do things in the garage...
Thanks!
Don
donste2010 is offline   Reply With Quote
Old 09-17-2020, 07:33 AM   #2
Rewards Points: 284
Re: Vapor barrier in garage?
how warm do you want to keep this garage ? always heated or just when you are out there ? going to park a daily driven car in there ?
Fix'n it is offline   Reply With Quote
Old 09-17-2020, 08:02 AM   #3
donste2010's Avatar
Rewards Points: 160
Thumbs up
Warm just when I'm in there, prolly not a daily but a winter project, I have heaters and such but I'd like it to warm up quickly in there...
Thanks!
Don
Old 09-18-2020, 10:34 AM   #4
Rewards Points: 284
just put up drywall and be done. and do your best to have the heat blow right where you will be working.
what kind of heater/s ?
donste2010 likes this.
The Following User Says Thank You to Fix'n it For This Useful Post:
donste2010 (09-18-2020)
Old 09-18-2020, 12:04 PM   #5
donste2010's Avatar
Rewards Points: 160
Smile
Just a small space heater and one that goes on top of a propane tank...
Old 09-18-2020, 12:24 PM   #6
Rewards Points: 450
I was taught vapor barrier always goes on the warm in winter side of the insulation. The idea is that water vapor moving from the building does not get to the insulation where it could condense and freeze and thereby prevent insulation/transfer of heat as solids (like ice) and liquids do conduct thermal energy. Also, prevents water from condensing and causing rot/mildew in walls.
donste2010 and Missouri Bound like this.
bob22 is offline   Reply With Quote
The Following User Says Thank You to bob22 For This Useful Post:
Old 09-18-2020, 12:31 PM   #7
Rewards Points: 284
what are the average cold temps in the winter ?
Old 09-18-2020, 12:48 PM   #8
donste2010's Avatar
Rewards Points: 160
Thumbs up
It will get below freezing in January at night, mid-30s at night the other winter months, mid 50s during the day...
Old 09-18-2020, 01:30 PM   #9
Rewards Points: 284
thats nothing. your propane heater may work well enough for you, i had one. put a small fan above and behind it to blow the heat at you.
heck, its 59 here right now, i could work in the garge in just a t-shirt.
average 20deg days here jan/feb, i had to step up to a small propane torpedo heater and it worked good. but i still had to dress well.
Old 09-18-2020, 03:10 PM   #10
Red Seal Electrician
Rewards Points: 512
Agreed with VB on the warm side.
I would not skip the VB - with drywall in particular - in the pacific northwest. Just asking for mold. Not sure how your region stacks up in this respect.
EDIT: Propane space heating creates a lot of humidity also.
donste2010 and Nealtw like this.
u2slow is offline   Reply With Quote
The Following User Says Thank You to u2slow For This Useful Post:
Old 09-24-2020, 08:38 PM   #11
Missouri Bound's Avatar
Rewards Points: 4,232
How large is your garage?
If you want to use it quite a bit in the cold months consider a permanently mounted heater.
As mentioned earlier, any portable heater, except electric will add humidity since it is not vented. Wall mount heaters can be vented through the wall and do a good job in a properly insulated space. The winters in my area are mild with some occasional cold spells in January. It is not uncommon for it to get to 3 deg. at night then 40 deg. the next day.
I have gone into my workshop and turned on the heat at 8AM on a 30 deg. day to shut it off by 10 and open the doors because the temp outside has risen 30 deg.
Do you want it your way or the right way?
Missouri Bound is online now   Reply With Quote
