Vapor Barrier In Garage - Insulation - DIY Chatroom Home Improvement Forum
Old 04-18-2016, 11:23 AM   #1
Rewards Points: 22
Vapor Barrier in garage
Insulating between the rafters in my attic truss of my non attached garage located in NE Oregon zone 5. Garage has a 10/12 roof so the attic truss is a nice storage area, has a finished floor in the attic and asphalt shingles on roof. Garage is wrapped with tyvek on the outside sheeting, sided with hardie board. Primary purpose of the insulation is to keep the attic area cooler during summer. I will be heating the garage in winter also but not that often.
So I'm insulating from the inside. Rafter cavities are vented from eave to peak and I built vent chutes with osb running the length of the rafter cavities with a 1.5" space to maintain air-flow (caulked and foamed for tight seal). Plan is to install batts between rafters against the osb vent chute and sheet over the rafters with osb for the finished ceiling.
The only insulation I can get locally is unfaced batts. With all the truss connections to the rafters running poly to face the insulation will be a pain. Is it necessary to have this vapor barrier with this type of insulation design. I guess same question for the walls downstairs and upstairs?
wildseamus is offline   Reply With Quote
Old 04-18-2016, 12:26 PM   #2
JUSTA MEMBER
Rewards Points: 200
Re: Vapor Barrier in garage
I think not needed.
A vapor barrier is used to keep any moisture that accumulates in a LIVING SPACE from getting into the cold attic causing ice dams in the winter.
This is an unattached garage, and will probably not have any cooking, shower, or laundry in it. to cause high humidity.
ED
de-nagorg is online now   Reply With Quote
Old 04-18-2016, 01:17 PM   #3
Rewards Points: 22
Yeah I just talked with 2 local contractors and 1 said it would be a good idea and the other one said it's probably ok to skip the vapor barrier so maybe someone else can chime in with more insight.
Old 04-18-2016, 01:35 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 928
Caulk and seal the gaps in the OSB and you should be fine.
The Following User Says Thank You to Windows on Wash For This Useful Post:
de-nagorg (04-18-2016)
Adding subpanel to Garage jimmyfloyd Electrical 2 11-09-2012 09:22 AM
Garage Roof Support & 2nd Floor Addition Info? olimits7 Building & Construction 3 10-15-2012 06:42 PM
Junction box feeding power to garage from house gmbojanowski23 Electrical 4 10-02-2012 10:20 AM
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 10:32 PM
