Vapor Barrier - Insulation - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By Nealtw
  • 1 Post By Bud9051
  • 1 Post By deepsweech
Old 03-06-2019, 10:33 AM   #1
Rewards Points: 54
Vapor Barrier
Hi,
I live in Massachusetts, doing a basement finishing. 80% below grade poured cement exterior walls are covered by 2in rigid foam and taped sealed. After putting in insulation, do I still need to put a vapor barrier?
deepsweech is offline   Reply With Quote
Old 03-06-2019, 10:46 AM   #2
retired framer
Rewards Points: 706
Re: Vapor Barrier
Don't know code there but did you seal the edges, the more air you can keep out of the system the better.
Windows on Wash likes this.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Old 03-06-2019, 03:52 PM   #3
Rewards Points: 192
Re: Vapor Barrier
Hi deepswitch,
Is that 2" of insulation on the inside or outside?
How old is the basement and what steps were taken to reduce typical moisture and water problems?
In most cases it is best to allow whatever moisture that might get through to evaporate to the air and not accumulate. But we don't know anything about the soil conditions on the outside. Tell us more and maybe a picture or two.
Bud
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is offline   Reply With Quote
Old 03-07-2019, 08:39 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 926
Re: Vapor Barrier
Originally Posted by deepsweech View Post
Hi,
What type of foam did you use. In the vast majority of cases...no. You do not need a vapor barrier.
You DO still want to use the ADA (Airtight Drywall Approach) so as to make sure the warm and moist air is not getting to a condensing surface.
Did you seal up the rim joists?
Old 03-07-2019, 09:20 AM   #5
Rewards Points: 54
Re: Vapor Barrier
Hi,
Used XPS foam. Yes, all rim joists sitting on the sill plates are spray foamed by the previous owner .
Old 03-07-2019, 10:21 AM   #6
Rewards Points: 926
Re: Vapor Barrier
No need them. Tape the seams (as you did), frame your wall, insulate (unfaced), and drywall. Detail out the interface between the drywall and the floor to be airtight and make sure all the electrical boxes are airtight as well.
Tags
vapor barrier
