Using Plastic Sheeting To Control Moisture In A Crawl Space - Insulation - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By SeniorSitizen
  • 1 Post By larryn3
Old 06-28-2018, 07:34 PM   #1
Rewards Points: 20
Using plastic sheeting to control moisture in a crawl space
Hi,
My crawl space presently has some old plastic sheeting on the dirt floor which has quite a few tears that are too large to patch. It was originally installed in 1991. I would like to either replace it or add another layer.
One question I have is whether I should remove all the old sheeting before laying down the new sheeting, or does it matter so long as I don't trap any moisture between the two layers? On occasion there was some outside surface water which got under the house due to some gutter issues that I have resolved. It is definitely though a bit moist under the old plastic in certain areas of the crawl space.
The second question I have is what thickness plastic should I use? It seems to me like 6 mil should be thick enough.
Lastly, any installation tips that folks may have would be appreciated.
Thanks in advance for any help anyone can provide.
Larryn3
larryn3 is offline   Reply With Quote
Old 06-28-2018, 07:47 PM   #2
retired framer
Rewards Points: 866
Re: Using plastic sheeting to control moisture in a crawl space
I wouldn't worry about the old, 6 mil is used when it is covered with concrete to protect it. I would want 8 or 10 subject to budget.
Any overlaps should be lapped by 12 inches and taped with tuck tape (red) and I would run it up the exterior walls to the level of the fill outside and stick it there.
In Canada we use Acoustic sealer, In the US I believe Quad is used.
Nealtw is offline   Reply With Quote
The Following User Says Thank You to Nealtw For This Useful Post:
larryn3 (06-28-2018)
Old 06-28-2018, 07:59 PM   #3
Rewards Points: 246
I agree with Neal except my preference (optional) would be to remove the old before adding new. If there is no Radon control you might take advantage of the change to add some vent pipes under the new plastic. That would be another topic, but testing would help you decide.
If you are in a cold climate then some rigid insulation on the walls would be good.
Bud
Bud9051 is offline   Reply With Quote
The Following User Says Thank You to Bud9051 For This Useful Post:
Old 06-28-2018, 08:07 PM   #4
Rewards Points: 402
Band aid over the top of band aid just gives termites a warm fuzzy feeling. Fix the real issue.
Old 06-28-2018, 08:16 PM   #5
retired framer
Rewards Points: 866
Do you have a plan for that fix.
Old 06-28-2018, 08:31 PM   #6
Rewards Points: 402
Yes, it is draining the water away from the structure.
Nealtw likes this.
Old 06-28-2018, 08:49 PM   #7
Rewards Points: 20
Water is no longer coming in under the house. My goal now is to reduce the moisture and humidity level that currently exists by insulating the dirt floor from the living area of the home.
Old 06-28-2018, 09:10 PM   #8
retired framer
Rewards Points: 866
As long as you are sure there is no other problem with water.
Old 06-28-2018, 09:18 PM   #9
Rewards Points: 20
Well, I am fairly certain that no further water will be coming in under the house. But, if it does, I would assume that its preferable for it to be under the plastic instead of being exposed.
Old 06-28-2018, 09:23 PM   #10
retired framer
Rewards Points: 866
Yes but you don't want a water bed under the house either. It would be something to watch for even after the job is done repairs can be done, perimeter drain inside or out sump and pump if necessary.
The ground can be inspected afterwards all you need is a knife, more plastic and tape.
Old 06-28-2018, 09:33 PM   #11
Rewards Points: 20
What I do know is that in the past, unless there was a very hard rain, no water ever came under the house. After I did some gutter and diversion work around the house perimeter, water now very rarely gets under the house. And, when it does, its always very minor now. However, I'm still working to get it completely stopped but I believe I'm at the point of trying to reduce the humidly level which is common under homes in our area.
Nealtw likes this.
Old 07-19-2018, 02:12 AM   #12
APA
Rewards Points: 384
You could try another layer of the 6 mil and see if that helps. There is no use building a sandcastle with a bulldozer. Crawlspaces are nightmare. Mine went from reasonably dry this summer do dripping after a high humidity week.
APA is offline   Reply With Quote
Sump pump needed in my crawl space? Jaco General DIY Discussions 3 11-29-2015 08:46 PM
Crawl Space Insulation in NWT Canada too-cold Insulation 3 11-10-2012 02:11 PM
Humidistat Control for Exhaust Fan in Crawl Space matthewd HVAC 2 10-17-2012 07:38 AM
Is my crawl space considered non-vented?? Mr Blotto Insulation 3 07-18-2012 09:52 AM
Best tape and sealant for 6 mil plastic sheeting in crawl space... nadsab Insulation 6 04-29-2011 11:18 PM
