Torn Flex Duct - Exposed Insukatio Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 12-12-2015, 11:19 AM   #1
Rewards Points: 180
Torn flex duct - exposed insukatio insulation
Alot of the HVAC flex duct in my house is torn on the inside. There are small tears and the insulation inside is exposed. We have inspected them and there are not tears on the outside. It must have been rodents or just degraded since they're fairly old.
We replaced the worst one in my two year olds room this summer but money didn't permit the rest. I was told by some HVAC people it wasn't a health problem but some have said that the fiberglass is in my system blowing around. I assume into the air and blowing fibers in.
I'm slightly paranoid and angry that I let it go this long. My better half thinks its not a major deal, claiming the insulation in the ducts isn't the super bad kind.
I am wondering if I should get on this pronto and the likelihood we could all end up with mesothelioma in ten years? Or, if we could replace one at a time as money allows.
boondocks95 is offline   Reply With Quote
Old 12-12-2015, 11:35 AM   #2
CompleteW&D's Avatar
Rewards Points: 524
Mesothelioma is a by-product of Asbestos, not fiberglass.
Just curious.... how are you seeing inside your flex ducts?
CompleteW&D is offline   Reply With Quote
Old 12-12-2015, 11:57 AM   #3
Rewards Points: 180
I was being extreme as I presume fiberglass is just as bad as asbestos only no one wants to admit it.
I can only see you top under the vents. I'm hoping they're not torn all the way thru and the rodents didn't go on an adventure but no way to know.
I did put some foil tape over the holes in the worst ones yesterday but I'm not sure that's a fix.
flex duct 90 deg bend_equivalent to 20 extra ft? tearitup HVAC 0 07-20-2015 04:49 PM
Duct Insulation bstaff03 General DIY Discussions 9 01-15-2013 09:25 AM
Jenn-Aire Downdraft - OEM flex duct required? Dwizzo Appliances 0 10-09-2010 04:35 PM
Wet insulation in flex ducts roberthall HVAC 4 12-10-2006 11:17 AM
Types of flex duct and support method wingam00 HVAC 1 06-04-2005 01:12 PM
