Tips On Applying Foam Board On Concrete - Insulation - DIY Chatroom Home Improvement Forum
Old 05-09-2015, 10:07 PM   #1
Rewards Points: 152
tips on applying foam board on concrete
Hi everyone, I am installing foam board on my concrete block walls in my workshop and was wondering if there is any trick to get it to stick to the walls? I am using adhesive that is recommended for foam board. Thanks all.
pointer80 is offline   Reply With Quote
Old 05-09-2015, 10:30 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
are you having problems or just getting set up ahead of time?
if you are having an actual problem now, describe the situation,.
Old 05-10-2015, 01:01 AM   #3
Rewards Points: 2,264
I find if I apply the adhesive in big dots every 12" or less it works better then a continuous zigzag pattern.
mae-ling is offline   Reply With Quote
Old 05-10-2015, 07:25 AM   #4
Rewards Points: 1,854
You are aware it should not be left exposed.
Old 05-10-2015, 08:31 AM   #5
nap
You talking to me?
nap's Avatar
if you are having problems getting it to stay stuck to the wall while the adhesive sets, use a board (2X4 or whatever) across the foam board and then use another stick type board to lean into that board and made secure at the floor to hold it all against the wall. You can do this in a couple places so the entire thing will be pressed against the wall, at least as much as the rigidity of the foam will allow.
The Following User Says Thank You to nap For This Useful Post:
mae-ling (05-10-2015)
Old 05-10-2015, 04:13 PM   #6
Rewards Points: 152
Thanks for the tips guys. The foam is sticking to the walls but the edges are not sticking very well but the seams are being taped with seam tape and the foam is a moisture barrier that will be sandwiched behind a stud wall.
Installing deck ledger board over foam board? RickT Building & Construction 9 04-27-2018 11:41 AM
Applying Strapping to Concrete dblandfo General DIY Discussions 2 10-31-2013 01:54 PM
Moldy blue foam board under floor joists zdennis General DIY Discussions 3 09-28-2013 12:58 PM
Concrete Basics for the DIYer Mort Concrete, Stone & Masonry 7 11-22-2012 11:19 AM
foam and foam board flammability bubbler Insulation 18 10-22-2011 01:18 AM
