Three Season Porch - Insulation - DIY Chatroom Home Improvement Forum
Old 09-05-2014, 07:38 AM   #1
Rewards Points: 93
Three Season Porch
Would like to insulate my porch before winter. Access is quite easy. Is it possible to use Tyvek as a barrier on the bottom of the joists and simply blow in insulation then seal the holes in the Tyvek??? Any inexpensive suggestions?
johnpma is offline   Reply With Quote
Old 09-05-2014, 10:38 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 906
Don't bother.
Use something like roxul or batt insulation and then cover with rigid foam to hold it in place.
That will help with the thermal bridging and make it more efficient.
Old 09-05-2014, 11:08 AM   #3
Residential Designer
AndyGump's Avatar
Rewards Points: 882
Send a message via Skype™ to AndyGump
It doesn't seem to make sense to spend the time and money to insulate the roof when the porch is not to be heated.
I am assuming it is not be heated as you only mentioned joists and not walls and have not stated that the porch was to be enclosed.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 09-05-2014, 11:56 AM   #4
Rewards Points: 93
yes the porch is enclosed with windows/screens. The wind whips up through the floor and makes it extremely cold. We keep our fire wood on the porch in the winter. I plastic all the windows for the winter
If building a 3 season porch over time... Jim McC Building & Construction 3 05-31-2013 12:14 PM
3 season porch dorcutt Building & Construction 6 02-25-2013 10:44 AM
Heat a 3 season porch green.willow HVAC 0 06-30-2012 05:22 AM
Building up a 4 season porch floor to match house floor level. mph7794 Flooring 1 06-27-2011 05:38 AM
Converting 3 season porch to 4 season....how should I do the floor? mph7794 Remodeling 3 06-24-2011 10:58 AM
