Thickness Of Foamboard For Bottom Plate? - Insulation - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By joecaption
Old 04-09-2018, 08:03 AM   #1
Rewards Points: 63
Thickness of foamboard for bottom plate?
Hi,
I was wondering what thickness of foamboard should I put under the bottom plate in my basement? I was thinking 1" attached to the floor with foamboard adhesive.
Geran Brown is offline   Reply With Quote
Old 04-09-2018, 08:54 AM   #2
Rewards Points: 1,892
Re: Thickness of foamboard for bottom plate?
If you use pressure treated wood there is no need for anything.
If your going with untreated wood use this.
https://www.homedepot.com/p/Owens-Co...-1FS/202084452
There is no need for anything thicker under a bottom plate.
chandler48 likes this.
Tags
basement , bottom plate , foam board , foamboard
1910 Beach Bungalows: Replacing all joists & subfloor on imperfect sill plate alheim Building & Construction 7 04-14-2015 07:43 AM
Attach Tapco Steel Adjustable Building Column to beam and bottom plate dropedBeam007 Building & Construction 8 10-13-2014 08:46 PM
What thickness of XPS/Roxul? mlowrie Insulation 7 04-17-2014 11:25 PM
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 08:50 PM
Top plate over header? zenman Building & Construction 6 08-05-2009 12:04 PM
