Thermal Barrier Needed At Top Of Walls? - Insulation - DIY Chatroom Home Improvement Forum
Old 09-29-2014, 12:43 PM   #1
Rewards Points: 83
Thermal barrier needed at top of walls?
I have these 2 inch thick foamboard panels on my walls and the tops are exposed as in this picture. They will be above a drop ceiling. Do these 2 inch wide areas need a thermal barrier if above a drop ceiling and if so how is that usually handled. Can I L over them with 3/4 boards?
pex006 is offline   Reply With Quote
Old 09-29-2014, 01:10 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 896
Drop ceiling should serve as the thermal barrier from a flame spread from inside the home.
If you are concerned, just cover them with 5/8" drywall.
The Following User Says Thank You to Windows on Wash For This Useful Post:
pex006 (10-04-2014)
Old 10-04-2014, 01:08 AM   #3
Rewards Points: 83
Thanks for the reply.
more thermal imaging - basement and walls SuperJETT Insulation 28 01-15-2013 04:16 PM
Thermal barrier for XPS foam board diyatx Insulation 6 12-10-2012 07:55 AM
PT wood needed on concrete walls too, right? jdm001 Building & Construction 4 11-13-2011 09:11 PM
Do I Need To Strap Exterior Walls (Interior Side) Before Drywall? Dreams Drywall & Plaster 4 09-26-2011 04:37 PM
Air and Thermal Barrier behind Tub on Extrior Wall bobpib Building & Construction 4 12-21-2009 08:09 AM
